hello friend i’ve a very big and annoyng probleme. let me explain. i’ve a gigabyte mobo with intel ich10r sata raid cotnroller. i’ve 2 velociraptor wdc150hlfs firmware 04.04v02 and windows 7 64bit ultimate.
i’ve this problem. many time system freeze for 15 or 30 or 1minute and then run again as if nothing had happened. and and it can happen 2 or 3 times a day but in some days it does not happen.
in eventviewer there are this The device \Device\Ide\iaStor0 did not respond within the timeout period. error id 9
i’ve applied a patch that rename registry keys iastor parameters in parameter.bad but nothing is changed. also freeze. what can i do??
