Best WD Elements Desktop External Hard Drive – Expert Advice to Choose
I researched the WD Elements Desktop external hard drive over the past few days because I need reliable storage for backups and large files. I checked reviews from sources like The New York Times, Consumer Reports, and Popular Mechanics, and these two models are often recommended:
WD 20TB Elements Desktop External Hard Drive
https://www.amazon.com/Elements-Desktop-External-external-storage/dp/B09VCXWPQ
Western Digital 8TB Elements Desktop External Hard Drive
https://www.amazon.com/Western-Digital-Elements-External-external/dp/B07D5V2ZX
However, I’m having trouble deciding if it’s the right choice or if the Seagate Expansion would be better.
I mainly want it for data backup, movies, games, and general storage. I don’t need SSD-level speed, but I do want good reliability and performance for long-term use. So which one should I buy? Or is there a better option I should consider?
Any recommendations will be appreciated. Thanks in advance!
