Hey folks, simple question on this one, what is the community recomended format for a USB Flash Drive when you wan too use it for files greater than 4gb? Looking in the manual, NTFS would be the choice, but I wanted to confirm that?
As I understand that FAT 32 does not support files larger than 4 or 5 gigs so you are left with NTSF for PC’s
NTSF is the format to use; no matter if you have the file on a hard drive OR a flash drive. NTFS accomodates large ISO and MKV files; FAT32 doesn’t.
