Sled-Driver said: What is better about 1.10.13?
I have wireless headphones which I use with WD TV, but I want to have the option of being able to turn off stereo sound when I’m not using the headphones, 1.10.13 allows that, the newer firmwares do not, after I watch videos I delete them, it takes one less step to delete with the old firmware, the new ones you have to go to edit-> then delete, there is no buffering arrow when playing videos, with the new firmware you see the arrow on the screen for 5 seconds or so before video starts and also the newer firmwares are finicky when playing files, the same files that would not play withe the 2 newer firmwares, play with the old firmware, isn’t that something?
