Be able to connect a PC/Mac directly through USB for transfer & maintenance
All in the title.
The USB that are used for expansion should also allow us to connect a PC or Mac like any regular hard drive, to do some maintenance if ever needed or even transfert files directly if the router goes off or any other problem.
Is there any reason you can’t just connect the drive to your computer directly via the Ethernet port (aside from certain newer Mac’s etc not having them)? That works very well and is quick for such maintenance and file transfer applications.
