I have a WDTV LIVE HD Media Player Version 1.02(i think)
My hd avi video stops at the last ten minutes (sometimes less)
Here’s some info about the files. Please help
General | |
Complete name : | C:\Downloads\BBC Planet Earth\BBC.Planet.Earth.05of11.Deserts.avi |
Format : | AVI |
Format/Info : | Audio Video Interleave |
Format profile : | OpenDML |
File size : | 2.12 GiB |
Duration : | 47mn 54s |
Overall bit rate : | 6 347 Kbps |
Writing application : | VirtualDubMod 1.5.10.2 (build 2540/release) |
Writing library : | VirtualDubMod build 2540/release |
Video | |
ID : | 0 |
Format : | MPEG-4 Visual |
Format settings, BVOP : | Yes |
Format settings, QPel : | No |
Format settings, GMC : | No warppoints |
Format settings, Matrix : | Default (H.263) |
Muxing mode : | Packed bitstream |
Codec ID : | DX50 |
Codec ID/Hint : | DivX 5 |
Bit rate : | 5 950 Kbps |
Width : | 1 280 pixels |
Height : | 720 pixels |
Display aspect ratio : | 16:9 |
Frame rate : | 25.000 fps |
Color space : | YUV |
Chroma subsampling : | 4:2:0 |
Bit depth : | 8 bits |
Scan type : | Progressive |
Bits/(Pixel*Frame) : | 0.258 |
Stream size : | 1.99 GiB (94%) |
Writing library : | DivX 6.2.5 (UTC 2006-07) |
Audio | |
ID : | 1 |
Format : | AC-3 |
Format/Info : | Audio Coding 3 |
Mode extension : | CM (complete main) |
Codec ID : | 2000 |
Bit rate mode : | Constant |
Bit rate : | 384 Kbps |
Channel(s) : | 6 channels |
Channel positions : | Front: L C R, Side: L R, LFE |
Sampling rate : | 48.0 KHz |
Bit depth : | 16 bits |
Video delay : | 28ms |
Stream size : | 132 MiB (6%) |
Alignment : | Split accross interleaves |
Interleave, duration : | 40 ms (1.00 video frame) |
Interleave, preload duration : | 500 ms |
