Auto mount encryption and removal encryption
Got an ext 2 ultra here ( 2 x 2TB WD Red ) setup encryption and after every reboot I need to mount the drives ( Raid 1 ) and and manually enter password for decrypting.
I was about to turn of encryption but whenever I click on modify in encryption setting I get an error:
" Error " Please select one item and ok button only . That’s it.
Any idea or input would help.
Hi nicoalbrecht,
Once the Volume encryption on the WD My Cloud EX2 Ultra device is configured, it can not be changed until you re-configure the RAID again, which is data destructive. Switching between manual and automatically mounted encryption volumes is also not possible once it has been set up during RAID configuration. For more information
you can refer to the link below:
