- I recently bought WD TV live and seagate theatre+ to compare and evaluate which one to keep. The main problem I see with WD TV live is the audio sync issues when running DVD movies
WD TV live was running .17 version. I had audio sync issues in running any of my DVD movies stored on hard drive. I dont get the same problem with theatre +. Then I upgraded the WD firmware to .24. still same problem.
with FW .24, it seems to effect LESS files than before . . . but it is still a major problem with a number of files that are playing just fine on other devices.
Yes I have just bought this device and having the same problems with audio sync with all videos of all formats, mainly mkv’s but generally any video is affected. I updated to 1.01.77 and this made the audio sync issue even more random. I have looked all over and can’t find a fix to this and I’m thinking of throwing this piece of junk into the bin.
Based on that firmware (1.01.77), you bought a WD TV HD Gen 2, not a WD TV Live (latest firmware 1.01.24).
If you have issues with your player, you need to post them in the correct forum:
