I am not having much luck ripping my .VOB files into .MKV through Handbrake.
The main reason is the delayed audio, i am converting music DVD’s to .MKV only to be able to skip to selected songs (since WDTV doesnt support DVD menus!)
i have tried the preset setting on Handbrake and then select the output file to .MKV but still no luck the audio is so delayed that it is not even watchable
I have tried the below setting (High profile)
Audio Codec is set at AAC (faac) with
Mixdown set on Stereo
Bitrate is set on 128
and another set up suggested on this forum
with Audio Codec set at AC3 passthru
but i get the same result
please assist
