Hi, I would like to get my 5:1 speaker to work as a speaker while playing movies? I got 2 options to do that
Option 1:The hdmi cable is connected to the speaker and then I can use the “Audio Out” port of the TV to connect to the speaker through composite cable.
Option 2: Directly connecting the WD player to the speaker through the composite cable.
Can you guys tell in which way I’ll get the better sound quality? Or is there any other better option that I’m missing. Please note that my speaker does not have any hdmi / spdif / optical port/
