I’d like my SMP to play albums by inspecting id3 data in the files in a given directory. Is the SMP not capable of this? Do I need to create a playlist?
Thanks.
Thanks.
Just have a look here:
@Steffen_2009
my copy’n’paste Kung-Fu is stronger than yours ! (here’s a “Working” link)
http://community.wdc.com/t5/WD-TV-Live-Streaming-Discussions/WD-Live-for-Audio-Files/td-p/523129
Oh, thanks for your correction Joey.
with copy 'n paste … I think I already had the MASTER belt,
but nothing in comparison with the real master:wink:
Regarding that thread - I have the media library “on” and id3 tags still don’t seem to be used. Songs in a particular directory are listed and played in alphabetical order.
bump - id3 tags still being ignored
How are you playing your music tracks.
Not sue what you mean - I go into “Music”, where there is a directory named the title of the album. If I click play at that point, the songs in the directory are played in alphabetical order. If I click ok and go into the directory and click ok on “Play Album”, I get the same behavior.
Yes, that is a correct behaviour.
To check the difference with libary “ON”:
Just hit the green botton on your remote on the music list or gallary view.
Here you can sort (now) by artist , album etc - not possible with libary and tags “off” .
Let’s have a happy new year !
Media libary is set to “on”; that hasn’t corrected the behavior.
Have you pressed the green button on your remote inside “music” ?
What did you choose there ?
