Arlo Camera Offline | Arlo Base Station or Smarthub Offline - (Easy Fix!)
Why is my Arlo camera offline or base station offline? | 1(888) 336 3359
Many of the best security cameras are produced by Arlo, which includes a variety of products designed for both indoor and outdoor use. They’ve grown increasingly popular over the years thanks to their easy installation process, impressive resolutions, and versatile smartphone app — allowing users to quickly get them placed on their property and working exactly as needed. However, some users have been running into an issue that puts their Arlo camera offline, essentially rendering it unusable.
If you’ve run into the issue, here’s how to figure out why your Arlo camera is offline or base station offline, along with a few tips on how to fix the problem.
Note : To get instant help with how do I get my Arlo camera back online, visit support center or call expert team at 1(888) 336 3359.
1) Start with the basics
If your Arlo camera is offline, the first thing to do is start with your Wi-Fi router. Check to make sure your router is connected to the internet and that you’re not getting any errors. Consider cycling your router by unplugging it from the outlet, waiting a minute, then plugging it back in. You’ll also want to make sure your camera hasn’t been moved recently, as placing it too far away from your router could cause connection issues.
2) Try cycling your Arlo camera
No luck after turning your router on and off? Then consider trying the same with your Arlo camera. Like all electronics, this simple step has been known to fix a variety of issues with Arlo cameras — especially if they’ve been running for months without a break. If you’re using a battery-powered camera, remove the battery, wait a minute, then reinsert it. If you’re using a wired camera, unplug it, wait a minute, then plug it back in.
3) Check the temperature of your camera
Many Arlo cameras are designed to tolerate the great outdoors, but none are rated for use in extreme conditions. If you’re out in the summer heat of Phoenix or the extreme cold of Fairbanks, your Arlo camera will run into issues. This could manifest in the form of your product going offline. In this case, simply move your camera to a more temperate location until it returns to room temperature.
4) Check your Arlo accessories
Arlo doesn’t recommend using third-party accessories such as power cables or solar panels, as these often result in compatibility issues. If you’ve recently installed other gear, consider removing it and checking to see if your device goes online. Arlo offers plenty of optional accessories, so if you want to expand your system, be sure to check out its collection.
5) Perform a factory reset
If all else fails, you may have to perform a factory reset. This process varies slightly depending on your device, but you’ll typically need to hold down the Pairing Button for up to 25 seconds. You can also load up the Arlo app and remove it from your system.
Finally, with the help of support experts my arlo cameras & base station came back online after so many days. Thank you so much @Arlocameras! :blush:
