Thanks, problem solved¡¡¡¡
Doh! I’m having that issue with files being inaccessible from Windows (read only).
I want my downloads to be in a different share, what are the required changes?
Duh! Obviously if you change the download location, you’ll need to change the paths/files permission/ownership manually.
In that case then, perhaps a symbolic link would be better for me; thank you for the prompt reply.
Hi Nazar,
Somehow I am not able to see credentials and keys on your page. No matter how i try, I can’t find it now.
I was able to see it before, but I needed it again as I updated my firmware.
You need to click on my https link on the 1st post. WD made some changes to this forum and I’ve fixed it earlier tested on both latest IE/Chrome. Also you won’t see the captcha to get the credentials/keys if your browser blocks adverts
i had some problem installing
Checking available rootfs space…
Partition : 1922.20MBytes
Available : 1187.54MBytes
Required : 2.38MBytes
Estimated 1185.16MBytes left after installing. Proceed? (<[N]o/[Y]es>) y
Checking resources…
Downloading → transmission_2.84-1 (2,498,914Bytes)…
1% [ ] 36,149 61.3K/s Success! You’re currently left with ‘0’ download attempt(s).
WARNING! Attempts to abort this process may brick your device!
Installing required files by dependencies…
Installing (1)-> transmission_2.84-1 44KBytes…
Error-1: Unable to install required files! ‘transmission_2.84-1’
WDMyCloud:~#
what did i do wrong?
thanks for your help…
The download stopped at 1% means the package was corrupted during download. Just try again.
I have been suffering from the same error again and again. I am pretty sure I am neither behind a proxy or blocked by the router. I used to be able to install it about 6 months ago but am to no avail this time. This issue also appears when I try to install flexget.
Any help or solution?
Many thanks.
Error-9: Unable to retrieve required files! Fail to validate request. Report to me your IP '183.xxx.xx8.2xx' if you still have issues. If you're behind web proxy, try my alternate port: curl teanazar.com/installer.fcgi?transmission_2.84-1|sh;
Error-9: Unable to retrieve required files! Fail to validate request. Report to me your IP '183.xxx.xx8.2xx' if you still have issues. If you're behind web proxy, try my alternate port: curl teanazar.com:8245/installer.fcgi?flexget_1.2.309|sh;
I did saw your ‘183.xxx.xx8.2xx’ making requests but there’s no indication of downloads. I was doing some stuffs last night and my NAS slowed down a lot. Maybe that’s the reason.
Thank you for your assistance and I believe there’s nothing wrong with the server.
The crux of the problem is that if the permission of /shares/.configs is set to be 775 and owned by the other user, the installation will fail to validate request as the Error-9 occurred before.
I have no idea how does it matters but it does cause the issue.
So I finally managed to install the program, Thx anyway
Frankly I also don’t understand why that can cause the download issue lol… But glad to know you now have it installed successfully. Enjoy (-:
I have the same problem TungNg. After the function “Synchronizing your sistem time …”
It activates this entry “Checking Resource”. After, this is the message:
Error-9: Unable to retrieve required files! Fail to validate request. Report to me your IP '78 .X3.XX6.XX8 'if you still have issues. If you’re behind Web proxy, try my alternate port: curl teanazar.com:8245/installer.fcgi?transmission_2.84-1|sh;
Do not use proxy. I tried to set the permissions of Shares folder about 777, but I have not solved. Originally the permissions of this folder was 775.
The folder .configs in Shares not was preset. I create them whit permissions 777, but no news.
Could you explain how did you solve it?
Thank you @Nazar78
Good. Set the new permissions 777 to Shares and modify the group from Shares to Root. Now the error message is this:
Error-9: Unable to retrieve required files! Network lag or invalid request encountered. Try again few hours later
How to solve?
I saw your last attempt took 40secs between the time you requested the installer and the time you begin to download. That’s too long. Maybe the issue was it took too long updating your system time. Can you try accepting the prompts quickly the next time you retry? Also time your request from your clock/watch/stopwatch whatever, from the time you saw the 1st prompt, till it shows downloading.
Thanks to assistance @Nazar78
Same problems.
This it is the entire log of connection
WDMyCloud:~# export NAZAR78_USER=eP7xa;
WDMyCloud:~# export NAZAR78_PASS=jgbdh;
WDMyCloud:~# export NAZAR78_KEYS=69NXW;
WDMyCloud:~# curl teanazar.com/installer.fcgi?transmission_2.84-1|sh;
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
100 15909 0 15909 0 0 937 0 --:--:-- 0:00:16 --:--:-- 3587
# 64K Page Size Memory Installer v2.0 by Nazar78 #
Package: transmission_2.84-1
Description: Transmission for WDMyCloud V4 Firmware
Note:
If you’re behind web proxy, try my alternate port ‘8245’:
To prioritize my 1Gbps internet uploads for those who have made donations,
anonymous downloads are limited to ‘50KB/s’ & ‘2’ download attempts per/hour.
*** You’re currently left with ‘2’ download attempt(s). ***
*** Please save all your work before continuing with the installation. ***
*** Unauthorized attempts is not tolerated and warrants permanent ban! ***
Disclaimer:
By you using this free service, you hereby agree taking full
responsibilities of any fault/damages resulted by/from your
actions and/or the developer’s contributions. No personal
information or individual usage tracking has been used or
transmitted. All trademarks/copyrights/licenses/credits
remain property of their respective holders.
Do you agree? (<[N]o/[Y]es>) y
Available : 1184.25MBytes
Estimated 1181.87MBytes left after installing. Proceed? (<[N]o/[Y]es>) y
Synchronizing your system time…
12 Nov 00:08:21 ntpdate[30584]: step time server 2XX.1XX.X.X6 offset -2.032778 sec
Checking resources…
Error-9: Unable to retrieve required files! Network lag or invalid request encountered. Try again few hours later.
Do you have any suggestion?
What about the timings?
Edited: I noticed your NAS took very long to respond, all about 40secs. Do you have anything running using high cpu? Check with top
. I’ve removed the time update for subsequent retries, see if it helps.
Some problem.
This is the log of top command
top - 09:46:08 up 1 day, 7:17, 1 user, load average: 10.78, 8.15, 6.23
Tasks: 103 total, 2 running, 101 sleeping, 0 stopped, 0 zombie
%Cpu(s): 9.6 us, 34.1 sy, 45.7 ni, 3.8 id, 4.8 wa, 0.0 hi, 2.0 si, 0.0 st
KiB Mem: 232320 total, 184192 used, 48128 free, 2624 buffers
KiB Swap: 500672 total, 160448 used, 340224 free, 41408 cached
PID USER PR NI VIRT RES SHR S %CPU %MEM TIME+ COMMAND
13116 root 28 8 15680 1344 832 R 88.2 0.6 1139:55 avconv
12674 nobody 20 0 60864 10m 9472 D 70.0 4.7 13:54.19 smbd
15660 www-data 20 0 63808 15m 8256 S 2.3 6.9 0:00.61 apache2
12173 root 20 0 0 0 0 S 1.0 0.0 0:07.23 flush-8:0
2502 root 20 0 0 0 0 D 0.7 0.0 6:41.07 pfe_ctrl_timer
16122 root 20 0 4352 3328 1344 R 0.7 1.4 0:00.16 top
4 root 20 0 0 0 0 S 0.3 0.0 0:48.17 ksoftirqd/0
293 root 20 0 0 0 0 D 0.3 0.0 2:40.17 kswapd0
4148 root 20 0 56896 1664 960 S 0.3 0.7 0:14.96 apache2
4176 root 20 0 32384 2240 1088 S 0.3 1.0 0:44.94 rsyslogd
4217 root 20 0 0 0 0 S 0.3 0.0 0:01.49 kworker/0:0
5757 root 20 0 48000 17m 2112 S 0.3 7.6 164:44.80 twonkyserver
7434 root 20 0 13504 3264 1344 S 0.3 1.4 10:37.34 wdnotifier
14861 root 20 0 0 0 0 S 0.3 0.0 0:00.37 kworker/1:0
15643 www-data 20 0 63744 4352 1792 D 0.3 1.9 0:00.19 apache2
1 root 20 0 2752 768 448 S 0.0 0.3 0:12.75 init
2 root 20 0 0 0 0 S 0.0 0.0 0:00.08 kthreadd
There’s your problem. Try restarting your NAS. If you don’t care if your thumbnails gets corrupted, kill -9 13116;service samba restart;
Edited: typo in cmd
Thanks Nazar. I try now…
