My WDMyCloud has an anti-bot mechanism which I customized within http/ftp/ssh to keep it safe from unauthorised access. You got permanent banned because you tried to execute the script manual (usually bot does these). I’ve removed the ban.
You’re in Dubai yet the pings are almost 300ms. I’m in Asia and getting better 200ms pings to the US. This is the reason to the lag, you’ll need to check your network/ISP.
I don’t understand, if to installate Tr2.84 is enough:
This is Transmission v2.84 for firmware V4+ successfully built with 64K page size memory patch. For setups and details, refer to https://www.transmissionbt.com/.
The guide is very straightforward but obviously you’ll need to follow everything as nothing mentioned as optional. Please don’t do anything if you don’t understand because it’s risking of voiding your warranty or worst bricking the NAS. I suggest you do some research prior.
Even though his instructions are simple, they require some knowledge.
I’ve read his instructions several times until I felt confident to go forward and I believe Nazar did a good job explaining what each step does - nice step by step instrutions.
Those who don’t possess that minimal knowledge/understanding should not try these; it asks for troubles!
_ This is Transmission v2.84 for firmware V4+ successfully built with 64K page size memory patch. For setups and details , refer to _ https://www.transmissionbt.com/.
(bolds are on me)
That means Nazar does not give instructions on how to use Transmission: for that, you go to that link.
You can set to whichever paths you want as long as you know what you’re doing. The reason I made it public as default because not many of us knows how to deal with the ownerships and permissions. And the installer script don’t know which account you’re using to access :P I could easily find out and let the script auto config but this will led to privacy invasion which I don’t think many would agree.
I believe WD will still continue the 64K page size memory as it has been all this while for v4 firmwares. But we can only confirm when the new firmware has been released.
Hello, excuse my English . When attempting to download from Puty . I get the following error message rl: (7) Failed to connect to 116.14.95.5: Network is unreachable -bash: syntax error near unexpected token `7’ Thankyou
Yesterday I did an instalation on someone else MyCloud (v422, I think) and notice that my changes to settings.json are erased with transmission restart. Essencially, settings.json is reseted every time transmission starts (I could prove this by changing lines order - after Transmission restart they are back to original state).
Could this be a new Transmission problem, some new setting I don’t know about or firmware related?
BTW, I was defining a new watch folder (I remember, in my other previous instalations I had to add those lines and now they are already defined in default settings.json)
