[APP] Transmission various versions for firmware V4+ (04/2018)
#925
Wrong thread, post them here: [APP] FlexGet various versions for firmware V4+ (03/2015)
Anyway I have FlexGet v1.2.309 running on the latest firmware 04.05.00-315 and it’s running fine. Might help if you post your config so I can help debug, most probably it’s a result from the RSS content. Looks like you’re trying to login to a RSS site which might have changed its login page. If that’s the case, look for other alternative sites. Please post your config in the appropriate FlexGet thread thanks.
#926
Hey there! So i had figured out the auto removal of torrent in the list after it has been downloaded/completed, another thing is, is there a code i could add to log every torrent that transmission has downloaded? Thanks a lot!
#927
By the way, here is the code i found for the auto-removal of torrents from the list after it has completed download. I modified it to my settings and remove the authorization part since i dont have one for my transmission.
#!/bin/bash
#Auto-remove script for Transmission 2.92-2 on WD MyCloud ver 4.x.x
#Assumed 9091 default port and no authorization on Transmission
TORRENTLIST=transmission-remote -l | sed -e '1d;$d;s/^ *//' | cut -s -d " " -f 1
for TORRENTID in $TORRENTLIST
do
DL_COMPLETE=transmission-remote -t $TORRENTID -i | grep -c "Percent Done: 100%"
STE_STOPPED=transmission-remote -t $TORRENTID -i | grep -c "State: Seeding\|Stopped\|Finished\|Idle"
if [ $DL_COMPLETE -eq 1 ] && [ $STE_STOPPED -eq 1 ]; then
transmission-remote -t $TORRENTID -r
echo “Torrent #$TORRENTID processed.”
fi
done
echo “Process Completed.”
That’s it. Is there anything i could do to add a line/s for writing log of the processed torrent/removed torrent? Thanks guys!
#928
If you’re using the “script-torrent-done-filename” for the auto removal, make use of these environments:
TR_APP_VERSION
TR_TIME_LOCALTIME
TR_TORRENT_DIR
TR_TORRENT_HASH
TR_TORRENT_ID
TR_TORRENT_NAME
E.g. echo "$TR_TIME_LOCALTIME - Download complete $TR_TORRENT_NAME">>/shares/Public/Transmission/Downloaded.log
#929
That was fast! Thanks a lot! I will work on this tomorrow and let you know! Appreciate it!
#930
Oh, sorry, I was checking both Transmission and Flexget threads and I wrote on the wrong one.
Anyway, I’ll follow your recommendation and check my RSS site. If I get stuck again, I’ll post it in the right thread.
Thank you, Nazar!
#931
Just updated to WDMyCloud v04.05.00-315, seems to have no issues with transmission and sickrage! :slight_smile:
#932
My torrents are missing after I reboot Transmission.
Any idea?
#933
I have no issue of missing torrents after reboot. Any changes made to the config? To revert to default, stop the daemon, delete the config then start the daemon.
#934
How to I delete the config file? I’ve actually tried to uninstall and install back and still same issue.
#935
transmission-stop;
rm ~/.config/transmission-daemon/settings.json;
transmission-daemon;
#936
Didn’t work. Deleted the settings.json
Torrents still missing after transmission started.
Any other files to check?
I notice this happens after I add in the watch-dir
“watch-dir”: “/shares/Public/Transmission/torrents”,
“watch-dir-enabled”: true
The torrents cannot be added again since it has *.added extension after 1st round. Doesn’t resume folder checks?
#937
If you installed from my installer, the watch-dir has already been set to enabled for path /shares/Public/Transmission/Downloads. Meaning any *.torrent files place in this path will be automatically moved to /shares/Public/Transmission/torrents and added to the transmission list.
#938
I’ll have to try in out later as I will be away for 2 week… Will update here again if any issue.
Thanks Nazar78
#939
@Nazar78 when i install this: “_Another webGUI interface theme (Highly recommended! Thanks Joaco_AR for sharing in this thread):” how can i return to retail webGUI? any idea?
#940
The original webGUI is still there. Just revert your ~/.profile and crontab, unset TRANSMISSION_WEB_HOME or open a new SSH session. Then restart transmission.
#941
Please add my ip 212.90.45.139
#942
Add your IP to what…?
#944
0curl: (7) couldn’t connect to host at teanazar.com:80
#945
Cant connect to teanazar.com
or download
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
0 0 0 0 0 0 0 0 --:–:-- 0:01:03 --:–:-- 0curl: (7) Failed connect to teanazar.com:80; Connection timed out
