Thanks Franc. From your studies of Mod 01, seems unrelated.
Some further observation :
By disabling Idle3, it takes 20 seconds to autopark on idle.
Using hdparm to change APM to 0x7f yields the same 20 seconds as 0x60.
Update 1 :
WD10JPVT APM 0x80 Record 6 : 0001020602000002060000060400030200160001020602000002030000060600050A0016
WD10JPVX APM 0x60 Record 6 : 000102060200000206000006040003020016600001020602000002030000060600050A001660
WD1600BEVS APM 0x80 Record 6 : 0001020602000002060000060400030200160001020602000002030000060600050A0016
WD2500BEVS APM 0x80 Record 6 : 0001020602000002060000060400030200160001020602000002030000060600050A0016
WD5000BEVT APM 0x80 Record 6 : 0001020602000002060000060400030200160001020602000002030000060600050A0016
WD10EADS No APM Record 6 : 0001020602000002060000060400030200160001020602000002030000060600050A0016
WD5000LPVX APM 0x60 : Mod 02 almost identical with WD10JPVX
WD10JPVX Record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
WD10JPVT Record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
WD10JPVX Record 12 00016002120022000A000000000000010100
WD10JPVT Record 12 00015502280022000A000000000000030100
WD10JPVX Record 13 0001983A0F0F0102020A01010A0202040A00FFFF020300011E0A600804400B020000000000FFFF1000000000030A40420F00E0C81000C8000000050AA00FA005463C02000505B0D010000000C8000000D00700000A00000001011E640010000060273C00000008
WD10JPVT Record 13 0001983A0F0F0102020A01010A0202040100FFFF020350011E0A800804400B020000000000FFFF1000000000010A40420F00E0C8100000000000050AA00F0505B0D0100090010000D0070000000000000200
I’ve changed 0x60 to 0x80 on an old 500GB but APM stays at 0x60, so this is not the correct location.
WD10JPVX Record 39 000101005802001032000507000100028000C8008000008008100A050A14285F5F78808000080005800002001008000800600F003800000508008001000480000400180500
WD10JPVT Record 39 00010100C800001032000507000100028000C8008000008008100A050A14285F5F78808000080005800002001008000800600F00380000050800800100048000040018
WD10JPVX Record 41 000100E80360EAE803000014
WD10JPVT Record 41 0001000A003200E093040014
Summary : Records 4, 12, 39 and 41 are unlikely used for APM. Studying Records 6 and 13 now.
Update 2 :
Changed Record 6 offset 0x12 from 0x60 to 0x80, APM stays at 0x60. Idle3ctl was unable to read offset 0x25, so I couldn’t change it.
Changed Record 13 offset 0x60 from 0x60 to 0x80, APM stays at 0x60.
