I have a 2 TB hard drive from Maxtor hooked up to this WD box using a USB cable. I notice 2 problems with my WD box:
1) There’s an MKV movie file that the WD TV box won’t open up, but I can watch it fine on my PC using VLC. But I can open up other MKV files using this same WD TV box.
- Whenever I have a movie file that the WD TV box can’t open, all subsequent files will not open up either. But these subsequent files used to be able to be viewed before. So I reboot the WD TV box, and those subsequent files will then view OK.
Are these bugs on WD TV Live Plus, or is there a way to fix these 2 issues? Thanks.
