I have an mpeg file which plays without sound using the WDTV. I can
run it through ffmpeg and get a version which has audio; however, as I
have a number of these files, I’d rather not if I can avoid it. Based
on the mediainfo output, should it work?
ffmpeg line to “fix”:
time ffmpeg -i Prep_For_Sale.mpg -acodec mp2 -vcodec copy testoutput.mpg
Here’s what mediainfo says about the original:
General
Complete name : Prep_For_Sale.mpg
Format : MPEG-PS
File size : 336 MiB
Duration : 3mn 6s
Overall bit rate : 15.1 Mbps
Video
Format : MPEG Video
Format version : Version 2
Format profile : Main@High
Format settings, BVOP : Yes
Format settings, Matrix : Default
Duration : 3mn 6s
Bit rate mode : Variable
Bit rate : 14.4 Mbps
Nominal bit rate : 65.0 Mbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate : 29.970 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Interlaced
Scan order : Top Field First
Bits/(Pixel*Frame) : 0.232
Stream size : 321 MiB (95%)
Audio
Format : AC-3
Format/Info : Audio Coding 3
Mode extension : CM (complete main)
Duration : 3mn 6s
Bit rate mode : Constant
Bit rate : 384 Kbps
Channel(s) : 2 channels
Channel positions : Front: L R
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Video delay : -205ms
Stream size : 8.55 MiB (3%)
Text
ID : 224 (0xE0)-608-1
Format : EIA-608
Muxing mode : MPEG Video / EIA-708
Muxing mode, more info : Muxed in Video #1
Stream size : 0.00 Byte (0%)
