hey guys, sorry for posting another one of these:
Extra info: It seems to be tied to the audio. I remuxed it to the bare bones and kept adding things until it stopped working, and every time, it fails at the audio step. I also am completely up to date with firmwares as of March 2011.
General
Unique ID : 226147263332229276947410300239787778174 (0xAA2260EDD9284491BDB29FE0CC3AE07E)
Complete name : S:[Coalgirls]_Evangelion_2.22_You_Can_(Not)_Advance_(1920x1080_Blu-Ray_FLAC)_[D8704972].mkv
Format : Matroska
File size : 12.5 GiB
Duration : 1h 52mn
Overall bit rate : 16.0 Mbps
Movie name : Evangelion 2.22 You Can (Not) Advance
Encoded date : UTC 2010-06-03 22:08:56
Writing application : mkvmerge v3.4.0 (‘Rapunzel’) built on May 15 2010 09:38:20
Writing library : libebml v0.8.0 + libmatroska v0.9.0
Cover : Yes / Yes / Yes / Yes / Yes / Yes / Yes / Yes / Yes / Yes / Yes / Yes / Yes / Yes / Yes / Yes / Yes / Yes / Yes / Yes / Yes
Video
Format : AVC
Format profile : High@L5.0
Format settings, CABAC : Yes
Format settings, ReFrames : 8 frames
Format settings, GOP : N=1
Codec ID : V_MPEG4/ISO/AVC
Duration : 1h 52mn
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate : 23.976 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Title : Evangelion 2.22 You Can (Not) Advance
Writing library : x264 core 96 r1613 81e75e9
Encoding settings : cabac=1 / ref=8 / deblock=1:0:0 / analyse=0x3:0x133 / me=umh / subme=9 / psy=1 / psy_rd=0.80:0.20 / mixed_ref=1 / me_range=24 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-3 / threads=12 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / constrained_intra=0 / bframes=8 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / weightp=2 / keyint=250 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=crf / mbtree=1 / crf=14.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / ip_ratio=1.40 / aq=1:1.00
Audio
Format : FLAC
Format/Info : Free Lossless Audio Codec
Codec ID : A_FLAC
Duration : 1h 52mn
Bit rate mode : Variable
Channel(s) : 7 channels
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Title : 5.1 FLAC
Writing library : libFLAC 1.2.1 (UTC 2007-09-17)
Language : Japanese
Text #1
Format : **bleep**
Codec ID : S_TEXT/**bleep**
Codec ID/Info : Advanced Sub Station Alpha
Compression mode : Lossless
Title : Americanized English
Language : English
Text #2
Format : **bleep**
Title : Unamericanized English
Language : English
Text #3
Format : **bleep**
Title : Americanized English - Karaoke
Language : English
Menu
00:00:00.000 : en:00:00:00.000
00:00:13.013 : en:00:00:13.013
00:00:18.018 : en:00:00:18.018
00:00:25.025 : en:00:00:25.025
00:02:23.393 : en:00:02:23.393
00:05:47.889 : en:00:05:47.889
00:08:37.100 : en:00:08:37.100
00:09:35.575 : en:00:09:35.575
00:11:31.566 : en:00:11:31.566
00:14:49.013 : en:00:14:49.013
00:15:48.865 : en:00:15:48.865
00:17:08.653 : en:00:17:08.653
00:18:46.667 : en:00:18:46.667
00:21:20.112 : en:00:21:20.112
00:23:35.247 : en:00:23:35.247
00:26:35.928 : en:00:26:35.928
00:28:07.644 : en:00:28:07.644
00:31:06.031 : en:00:31:06.031
00:32:50.635 : en:00:32:50.635
00:35:11.359 : en:00:35:11.359
00:39:29.659 : en:00:39:29.659
00:41:03.586 : en:00:41:03.586
00:44:25.454 : en:00:44:25.454
00:48:59.854 : en:00:48:59.854
00:50:57.346 : en:00:50:57.346
00:53:12.773 : en:00:53:12.773
00:58:22.499 : en:00:58:22.499
01:00:29.876 : en:01:00:29.876
01:01:07.581 : en:01:01:07.581
01:06:17.682 : en:01:06:17.682
01:08:19.971 : en:01:08:19.971
01:10:44.157 : en:01:10:44.157
01:11:35.249 : en:01:11:35.249
01:14:16.577 : en:01:14:16.577
01:25:24.244 : en:01:25:24.244
01:27:41.631 : en:01:27:41.631
01:29:45.380 : en:01:29:45.380
01:34:47.473 : en:01:34:47.473
01:36:57.645 : en:01:36:57.645
01:38:52.844 : en:01:38:52.844
01:41:15.194 : en:01:41:15.194
01:45:56.058 : en:01:45:56.058
01:51:34.688 : en:01:51:34.688
