After trying about 50 music apps from google store (without success)
I tried a different kernel with cifs support again.
Yesterday night it was sucessfully !!
I simply had to mount with cifsmanager (with MountManager and terminal it is still not working).
So after weeks of going through the **bleep** of cifs I finally followed KAD79
"… I would try cifsmanager from google play … " and used the cifsManager again.
You gave me the right direction KAD79, thank you thousand times !
My mistake:
I tried to mount (only) the IP (192.168.0.x) of our WD SMP and
I just had no or just one “/” before the IP
Correct is:
Mounting the IP of WD SMP *AND*
the HDD device name (my directly connected USB-device has the name HD_ALPHA),
so I must use at least //192.168.0.x/HD_ALPHA
Now it is possible to set a local mount-path to the USB-device on my HTC mobile and even set
the same mount-path inside the UpNP App BubbleUpnP.
Now the WD SMP can play directly complete folders from the attached HDD without running a
Twonky server or having to turn on the TV for navigation :dizzy_face:
