I have recently brought this product from the United States. Im trying to use it as it is advised by WD , but it seems impossible, since every time I try to upload files into it, I get:
Incredibly slow pre-2000year upload speed (see picture, 25 minutes for 200mb).
Huge lags when try to navigate the unit using finder.
No matter if I place my brand new macbook computer just next to the internet router, and every device is connected to same LAN. The speed I get makes the device absolutely useless. It cannot work like this… There must be something wrong.
There must be a way out of this, please WD team. I will be waiting for your help.
I had the same problem a few days ago. Prior to this, there was a stable speed throughout the year (about 75 megabytes per second). I noticed that the speed dropped after updating WD Discovery to version 3.2.256.
I have same trouble too. Although WD show “Local” connection but transfer speed is very slow. i think data still upload to wd server and back to our WD home cloud then. It is not upload direct to WD home cloud in LAN. Noone helps us???
There is a solution for that. Return it, then buy a real NAS. This is not a NAS. This is a device that shouldn’t exist. Not with that branding name anyway.
Completely normal for this extremely slow drive. It took me 4 days to sync 650GB of graphics files. Then this new software update screwed everything up…now I’m having to resync everything again. This is the last time then I’m going to look for a normal NAS. I’m realizing this thing was a mistake.
