Mannnn unlucky! I had the newest version working and happy. Noticed on the WebGUI that the Resource Manager status wasn’t populated. SSH’ed in to find those large, 6-letter files in /tmp filling everything up. I deleted them and rebooted, but now samba is down, the website is down, and SSH/Telnet is down. I popped the drives out to go to recovery, and the website is there, but no Telnet/SSH access. I speculate that those libraries are corrupt, but seems I’ll need to UART into it to replace them.
I bricked it the last time (on older firmware) after enabling disk hibernation. I left disk hibernation on for this install, and it seems it’s been bricked again. Does anyone have any corroborating evidence that might link these failures to that feature?
Edit: Here’s the log of the failure to boot. This is UART output with both drives seated:
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Initializing cgroup subsys cpuacct
[ 0.000000] Linux version 3.10.35 (root@build64) (gcc version 4.9.3 20150311 (prerelease) (crosstool-NG 1.20.0) ) #4 SMP Sun Feb 26 22:09:56 +05 2017
[ 0.000000] CPU: ARMv7 Processor [414fc091] revision 1 (ARMv7), cr=10c53c7d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000] Machine: Marvell Armada 380/381/382/383/384/385/388 (Device Tree), model: WD MyCloud Mirror gen2 (Armada 385)
[ 0.000000] Memory policy: ECC disabled, Data cache writealloc
[ 0.000000] PERCPU: Embedded 8 pages/cpu @c0d7c000 s8320 r8192 d16256 u32768
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 130048
[ 0.000000] Kernel command line: console=ttyS0,115200 root=/dev/md0 syno_hw_version=DS216 ihd_num=2 netif_num=1
[ 0.000000] Synology Hardware Version: DS216-j
[ 0.000000] Internal HD num: 2
[ 0.000000] Internal netif num: 1
[ 0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.000000] allocated 1048576 bytes of page_cgroup
[ 0.000000] please try 'cgroup_disable=memory' option if you don't want memory cgroups
[ 0.000000] Memory: 512MB = 512MB total
[ 0.000000] Memory: 506180k/506180k available, 18108k reserved, 0K highmem
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
[ 0.000000] vmalloc : 0xe0800000 - 0xfff00000 ( 503 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xe0000000 ( 512 MB)
[ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
[ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
[ 0.000000] .text : 0xc0008000 - 0xc06558bc (6455 kB)
[ 0.000000] .init : 0xc0656000 - 0xc0690080 ( 233 kB)
[ 0.000000] .data : 0xc0692000 - 0xc06d9a40 ( 287 kB)
[ 0.000000] .bss : 0xc06d9a40 - 0xc074e224 ( 466 kB)
[ 0.000000] Hierarchical RCU implementation.
[ 0.000000] RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=2.
[ 0.000000] NR_IRQS:16 nr_irqs:16 16
[ 0.000000]
[ 0.000000] LSP version: linux-3.10.70-2015_T1.1p4
[ 0.000000]
[ 0.000000] sched_clock: 32 bits at 25MHz, resolution 40ns, wraps every 171798ms
[ 0.000000] L310 cache controller enabled
[ 0.000000] l2x0: 16 ways, CACHE_ID 0x410054c9, AUX_CTRL 0x16070000, Cache size: 1048576 B
[ 0.000456] Calibrating delay loop... 2655.84 BogoMIPS (lpj=13279232)
[ 0.060028] pid_max: default: 32768 minimum: 301
[ 0.060080] Security Framework initialized
[ 0.060090] AppArmor: AppArmor initialized
[ 0.060109] Mount-cache hash table entries: 512
[ 0.061617] Initializing cgroup subsys memory
[ 0.061635] Disabling memory control group subsystem
[ 0.061639] Initializing cgroup subsys devices
[ 0.061643] Initializing cgroup subsys freezer
[ 0.061646] Initializing cgroup subsys blkio
[ 0.061672] CPU: Testing write buffer coherency: ok
[ 0.061782] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.061815] Setting up static identity map for 0xc04c3fb0 - 0xc04c4008
[ 0.061950] mvebu-pmsu: Initializing Power Management Service Unit
[ 0.061984] Initializing CPU Reset module
[ 0.061993] Synology DS216 GPIO Init
[ 0.062683] CPU1: Booted secondary processor
[ 0.121753] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[ 0.121813] Brought up 2 CPUs
[ 0.121823] SMP: Total of 2 processors activated (5311.69 BogoMIPS).
[ 0.121825] CPU: All CPU(s) started in SVC mode.
[ 0.122125] devtmpfs: initialized
[ 0.124361] mvebu-soc-id: MVEBU SoC ID=0x6820, Rev=0x4
[ 0.124525] xor: measuring software checksum speed
[ 0.221634] arm4regs : 2365.600 MB/sec
[ 0.321535] 8regs : 1630.400 MB/sec
[ 0.421434] 32regs : 1658.800 MB/sec
[ 0.421438] xor: using function: arm4regs (2365.600 MB/sec)
[ 0.421444] pinctrl core: initialized pinctrl subsystem
[ 0.421726] regulator-dummy: no parameters
[ 0.421882] NET: Registered protocol family 16
[ 0.422440] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.424487] irq: Cannot allocate irq_descs @ IRQ194, assuming pre-allocated
[ 0.424849] irq: Cannot allocate irq_descs @ IRQ226, assuming pre-allocated
[ 0.427622] hw-breakpoint: found 5 (+1 reserved) breakpoint and 1 watchpoint registers.
[ 0.427627] hw-breakpoint: maximum watchpoint size is 4 bytes.
[ 0.435203] bio: create slab <bio-0> at 0
[ 0.601284] raid6: int32x1 199 MB/s
[ 0.771296] raid6: int32x2 274 MB/s
[ 0.941001] raid6: int32x4 274 MB/s
[ 1.110818] raid6: int32x8 303 MB/s
[ 1.110822] raid6: using algorithm int32x8 (303 MB/s)
[ 1.110826] raid6: using intx1 recovery algorithm
[ 1.111071] mvebu-pcie pcie-controller.6: PCI host bridge to bus 0000:00
[ 1.111082] pci_bus 0000:00: root bus resource [io 0x1000-0xfffff]
[ 1.111088] pci_bus 0000:00: root bus resource [mem 0xe0000000-0xe7ffffff]
[ 1.111094] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 1.111111] PCI: bus0: Fast back to back transfers enabled
[ 1.111241] reg-fixed-voltage vbus-gpio.5: could not find pctldev for node /soc/internal-regs/pinctrl/vbus-gpio-pin, deferring probe
[ 1.111252] platform vbus-gpio.5: Driver reg-fixed-voltage requests probe deferral
[ 1.111710] SCSI subsystem initialized
[ 1.112094] platform usb3_phy.4: Driver nop_usb_xceiv requests probe deferral
[ 1.112336] pps_core: LinuxPPS API ver. 1 registered
[ 1.112340] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 1.112387] PTP clock support registered
[ 1.112914] Switching to clocksource armada_370_xp_clocksource
[ 1.113094] AppArmor: AppArmor Filesystem Enabled
[ 1.114136] NET: Registered protocol family 2
[ 1.114388] TCP established hash table entries: 4096 (order: 3, 32768 bytes)
[ 1.114430] TCP bind hash table entries: 4096 (order: 3, 32768 bytes)
[ 1.114468] TCP: Hash tables configured (established 4096 bind 4096)
[ 1.114490] TCP: reno registered
[ 1.114497] UDP hash table entries: 256 (order: 1, 8192 bytes)
[ 1.114509] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
[ 1.114609] NET: Registered protocol family 1
[ 1.114743] RPC: Registered named UNIX socket transport module.
[ 1.114748] RPC: Registered udp transport module.
[ 1.114751] RPC: Registered tcp transport module.
[ 1.114754] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 1.114845] Trying to unpack rootfs image as initramfs...
[ 2.895436] Freeing initrd memory: 4952K (c0f01000 - c13d7000)
[ 2.895619] hw perfevents: enabled with ARMv7 Cortex-A9 PMU driver, 7 counters available
[ 2.897081] audit: initializing netlink socket (disabled)
[ 2.897103] type=2000 audit(2.890:1): initialized
[ 2.898388] VFS: Disk quotas dquot_6.5.2
[ 2.898447] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 2.898778] NFS: Registering the id_resolver key type
[ 2.898799] Key type id_resolver registered
[ 2.898803] Key type id_legacy registered
[ 2.898825] msgmni has been set to 998
[ 2.899388] async_tx: api initialized (async)
[ 2.899581] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 251)
[ 2.899587] io scheduler noop registered
[ 2.899604] io scheduler cfq registered (default)
[ 2.900480] armada-38x-pinctrl f1018000.pinctrl: registered pinctrl driver
[ 2.900993] mv_xor f1060800.xor: Marvell shared XOR driver
[ 2.933366] mv_xor f1060800.xor: Marvell XOR (Descriptor Mode): ( xor cpy intr pq )
[ 2.963279] mv_xor f1060800.xor: freeing 1 in use descriptors!
[ 2.963290] mv_xor f1060800.xor: Marvell XOR (Descriptor Mode): ( intr crc32c )
[ 2.964403] mv_xor f1060900.xor: Marvell shared XOR driver
[ 3.003289] mv_xor f1060900.xor: Marvell XOR (Descriptor Mode): ( xor cpy intr pq )
[ 3.033302] mv_xor f1060900.xor: freeing 1 in use descriptors!
[ 3.033312] mv_xor f1060900.xor: Marvell XOR (Descriptor Mode): ( intr crc32c )
[ 3.034895] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 3.057089] f1012000.serial: ttyS0 at MMIO 0xf1012000 (irq = 44) is a 16550A
[ 3.819040] console [ttyS0] enabled
[ 3.843044] f1012100.serial: ttyS1 at MMIO 0xf1012100 (irq = 45) is a 16550A
[ 3.853274] brd: module loaded
[ 3.856342] Loading iSCSI transport class v2.0-870.
[ 3.863834] ahci_mv f10a8000.sata: AHCI 0001.0000 32 slots 2 ports 6 Gbps 0x3 impl platform mode
[ 3.872665] ahci_mv f10a8000.sata: flags: 64bit ncq sntf led only pmp fbs pio slum part sxs
[ 3.883114] scsi0 : ahci_mv_platform
[ 3.887232] scsi1 : ahci_mv_platform
[ 3.891304] ata1: SATA max UDMA/133 mmio [mem 0xf10a8000-0xf10a9fff] port 0x100 irq 58
[ 3.899277] ata2: SATA max UDMA/133 mmio [mem 0xf10a8000-0xf10a9fff] port 0x180 irq 58
[ 3.910029] armada-nand f10d0000.nand: Initialize HAL based NFC in 8bit mode with DMA Disabled using BCH 4bit ECC
[ 3.924435] NAND device: Manufacturer ID: 0xad, Chip ID: 0xda (Hynix NAND 256MiB 3,3V 8-bit), 256MiB, page size: 2048, OOB size: 64
[ 3.936553] Bad block table found at page 131008, version 0x01
[ 3.942761] Bad block table found at page 130944, version 0x01
[ 3.948938] 8 ofpart partitions found on MTD device armada-nand
[ 3.954920] Creating 8 MTD partitions on "armada-nand":
[ 3.960168] 0x000000000000-0x000000500000 : "U-Boot"
[ 3.966283] 0x000000500000-0x000000a00000 : "uImage"
[ 3.972518] 0x000000a00000-0x000000f00000 : "uRamdisk"
[ 3.978861] 0x000000f00000-0x00000c800000 : "image.cfs"
[ 3.985226] 0x00000c800000-0x00000d700000 : "rescue fw"
[ 3.991714] 0x00000d700000-0x00000eb00000 : "config"
[ 3.997850] 0x00000eb00000-0x00000f500000 : "reserve1"
[ 4.004082] 0x00000f500000-0x00000ff00000 : "reserve2"
[ 4.013907] SoC: model = 0x6820, revision = 0x4
[ 4.018524] mvPncVirtBase = 0xe1c00000, pncTcamSize = 1024
[ 4.024053] o 3 Giga ports supported
[ 4.027817] o SKB recycle supported for SWF (Disabled)
[ 4.033159] o NETA acceleration mode 4
[ 4.037096] o BM supported for CPU: 4 BM pools
[ 4.041730] o PnC supported (Enabled)
[ 4.045595] o RX Queue support: 8 Queues * 256 Descriptors
[ 4.051278] o TX Queue support: 8 Queues * 532 Descriptors
[ 4.056967] o GSO supported
[ 4.059943] o GRO supported
[ 4.062919] o Receive checksum offload supported
[ 4.067735] o Transmit checksum offload supported
[ 4.072629] o Driver ERROR statistics enabled
[ 4.077179] o Driver INFO statistics enabled
[ 4.081638] o Driver DEBUG statistics enabled
[ 4.086187]
[ 4.088728] port #2: is_sgmii=1, is_rgmii=0, phy_addr=0
[ 4.094016] o Loading network interface(s) for port #2: cpu_mask=0x3, tx_csum_limit=2048
[ 4.102328]
[ 4.103828] o Port 2 is connected to Linux netdevice
[ 4.113402] o eth0, ifindex = 2, GbE port = 2
[ 4.118141] o eth0, phy chipid = 1410dd0, Support WOL = 32
[ 4.127424] giga p=2: mtu=1500, mac=00:50:43:02:02:03 (platform)
[ 4.133561]
[ 4.135782] libphy: orion_mdio_bus: probed
[ 4.140049] mdio_bus f1072004.mdio-mi: cannot get PHY at address 1
[ 4.146428] mdio_bus f1072004.mdio-mi: cannot get PHY at address 4
[ 4.155794] mvebu-rtc f10a3800.rtc: rtc core: registered f10a3800.rtc as rtc0
[ 4.223120] i2c /dev entries driver
[ 4.238817] thermal thermal_zone0: Temperature sensor reading not valid
[ 4.245477] thermal thermal_zone0: failed to read out thermal zone 0
[ 4.252139] md: linear personality registered for level -1
[ 4.257663] md: raid0 personality registered for level 0
[ 4.263015] md: raid1 personality registered for level 1
[ 4.268348] md: raid10 personality registered for level 10
[ 4.273859] md: raid6 personality registered for level 6
[ 4.279190] md: raid5 personality registered for level 5
[ 4.284526] md: raid4 personality registered for level 4
[ 4.290094] device-mapper: ioctl: 4.24.0-ioctl (2013-01-15) initialised: dm-devel@redhat.com
[ 4.298582] cpuidle: using governor ladder
[ 4.303131] ledtrig-cpu: registered to indicate activity on CPUs
[ 4.309567] armada-cesa-ocf f109d000.crypto: mv_get_cesa_resources: Total CESA HW channels supported 2
[ 4.318931] armada-cesa-ocf f109d000.crypto: mv_get_cesa_resources: CESA feature: int_coalescing(1)
[ 4.328027] armada-cesa-ocf f109d000.crypto: mv_get_cesa_resources threshold 0x2, threshold_time 0xfffff
[ 4.337752] mvCesaInit: channels=2, session=640, queue=256
[ 4.354267] armada-cesa-ocf f109d000.crypto: cesa_ocf_probe: CESA driver operate in ocf(0) mode
[ 4.363683] cesadev_init(c0675348)
[ 4.367799] TCP: cubic registered
[ 4.371130] NET: Registered protocol family 17
[ 4.375664] Key type dns_resolver registered
[ 4.379989] VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4
[ 4.390532] registered taskstats version 1
[ 4.394906] regulator-dummy: disabling
[ 4.401675] vbus-gpio: 5000 mV
[ 4.416262] input: gpio_keys.3 as /devices/soc.0/internal-regs.1/gpio_keys.3/input/input0
[ 4.434994] mvebu-rtc f10a3800.rtc: setting system clock to 2017-05-15 01:57:02 UTC (1494813422)
[ 4.462958] ata2: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[ 4.469182] ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[ 4.475485] ata2.00: ATA-9: WDC WD20EFRX-68EUZN0, 82.00A82, max UDMA/133
[ 4.482220] ata2.00: 3907029168 sectors, multi 0: LBA48 NCQ (depth 31/32)
[ 4.489191] ata1.00: ATA-9: WDC WD20EFRX-68EUZN0, 82.00A82, max UDMA/133
[ 4.495939] ata1.00: 3907029168 sectors, multi 0: LBA48 NCQ (depth 31/32)
[ 4.502841] ata2.00: configured for UDMA/133
[ 4.507224] ata1.00: configured for UDMA/133
[ 4.512077] scsi 0:0:0:0: Direct-Access WDC WD20EFRX-68EUZN0 82.0 PQ: 0 ANSI: 5
[ 4.523348] sd 0:0:0:0: [sda] 3907029168 512-byte logical blocks: (2.00 TB/1.81 TiB)
[ 4.531134] sd 0:0:0:0: [sda] 4096-byte physical blocks
[ 4.539995] sd 0:0:0:0: [sda] Write Protect is off
[ 4.542091] scsi 1:0:0:0: Direct-Access WDC WD20EFRX-68EUZN0 82.0 PQ: 0 ANSI: 5
[ 4.553403] sd 1:0:0:0: [sdb] 3907029168 512-byte logical blocks: (2.00 TB/1.81 TiB)
[ 4.553406] sd 1:0:0:0: [sdb] 4096-byte physical blocks
[ 4.553499] sd 1:0:0:0: [sdb] Write Protect is off
[ 4.553544] sd 1:0:0:0: [sdb] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 4.581863] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 4.603886] sdb: sdb1 sdb2 sdb3
[ 4.612467] sda: sda1 sda2 sda3
[ 4.617736] sd 1:0:0:0: [sdb] Attached SCSI disk
[ 4.640899] sd 0:0:0:0: [sda] Attached SCSI disk
[ 4.645718] Freeing unused kernel memory: 232K (c0656000 - c0690000)
START /linuxrc.syno
Insert basic USB modules...
:: Loading module usb-common ... [ OK ]
:: Loading module usbcore[ 4.847724] usbcore: registered new interface driver usbfs
[ 4.854129] usbcore: registered new interface driver hub
[ 4.865046] usbcore: registered new device driver usb
... [ OK ]
:: Loading module ehci-hcd[ 4.891405] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
... [ OK ]
:: Loading module xhci-hcd[ 4.929348] xhci-hcd f10f8000.usb3: failed to get Vbus gpio
[ 4.934985] xhci-hcd f10f8000.usb3: USB2 Vbus gpio -1
[ 4.940064] xhci-hcd f10f8000.usb3: power control disabled
[ 4.945601] xhci-hcd f10f8000.usb3: xHCI Host Controller
[ 4.950948] xhci-hcd f10f8000.usb3: new USB bus registered, assigned bus number 1
[ 4.958629] xhci-hcd f10f8000.usb3: irq 49, io mem 0xf10f8000
[ 4.965092] hub 1-0:1.0: USB hub found
[ 4.968874] hub 1-0:1.0: 1 port detected
[ 4.972975] xhci-hcd f10f8000.usb3: USB3 Vbus gpio -1
[ 4.978056] xhci-hcd f10f8000.usb3: power control disabled
[ 4.983589] xhci-hcd f10f8000.usb3: xHCI Host Controller
[ 4.988937] xhci-hcd f10f8000.usb3: new USB bus registered, assigned bus number 2
[ 4.999226] hub 2-0:1.0: USB hub found
[ 5.003041] hub 2-0:1.0: 1 port detected
... [ OK ]
:: Loading module ehci-orion[ 5.054677] ehci-orion: EHCI orion driver
... [ OK ]
Insert net driver(Mindspeed only[ 5.075550] synobios: load, major number 201
Starting /usr/syno/bin/synocfgen...
/usr/syno/bin/synocfgen returns 0
[ 5.093942] synobios: unload
[ 5.115293] md: Autodetecting RAID arrays.
[ 5.155614] md: invalid raid superblock magic on sda3
[ 5.160691] md: sda3 does not have a valid v0.90 superblock, not importing!
[ 5.217863] md: invalid raid superblock magic on sdb3
[ 5.222950] md: sdb3 does not have a valid v0.90 superblock, not importing!
[ 5.229948] md: Scanned 6 and added 4 devices.
[ 5.234415] md: autorun ...
[ 5.237219] md: considering sda1 ...
[ 5.240815] md: adding sda1 ...
[ 5.244068] md: sda2 has different UUID to sda1
[ 5.248622] md: adding sdb1 ...
[ 5.251864] md: sdb2 has different UUID to sda1
[ 5.256428] md: created md0
[ 5.259232] md: bind<sdb1>
[ 5.261975] md: bind<sda1>
[ 5.264712] md: running: <sda1><sdb1>
[ 5.268699] md/raid1:md0: active with 2 out of 2 mirrors
[ 5.274081] md0: detected capacity change from 0 to 2549940224
[ 5.280118] md: considering sda2 ...
[ 5.283743] md: adding sda2 ...
[ 5.287001] md: adding sdb2 ...
[ 5.292391] md: created md1
[ 5.295232] md: bind<sdb2>
[ 5.297984] md: bind<sda2>
[ 5.300730] md: running: <sda2><sdb2>
[ 5.306460] md/raid1:md1: not clean -- starting background reconstruction
[ 5.313295] md/raid1:md1: active with 2 out of 2 mirrors
[ 5.318702] md1: detected capacity change from 0 to 2147418112
[ 5.324833] md: ... autorun DONE.
[ 5.326789] md: md1: current auto_remap = 0
[ 5.326793] md: resync of RAID array md1
[ 5.326794] md: minimum _guaranteed_ speed: 1000 KB/sec/disk.
[ 5.326796] md: using maximum available idle IO bandwidth (but not more than 200000 KB/sec) for resync.
[ 5.326800] md: using 128k window, over a total of 2097088k.
Partition Version=8
/sbin/e2fsck exists, checking /dev/md0...
[ 5.896348] md0: unknown partition table
1.42.6-8438: recovering journal
26190 inodes used (16.83%, out of 155648)
80 non-contiguous files (0.3%)
11 non-contiguous directories (0.0%)
# of inodes with ind/dind/tind blocks: 0/0/0
Extent depth histogram: 24246/13
224199 blocks used (36.01%, out of 622544)
0 bad blocks
1 large file
21356 regular files
2612 directories
2 character device files
0 block device files
0 fifos
1315 links
2211 symbolic links (1921 fast symbolic links)
0 sockets
27496 files
/sbin/e2fsck returns 1
Mounting /dev/md0 /tmpRoot
[ 7.468942] EXT4-fs (md0): barriers disabled
[ 7.483211] EXT4-fs (md0): mounted filesystem with ordered data mode. Opts:
------------upgrade
Begin upgrade procedure
No upgrade file exists
End upgrade procedure
============upgrade
Wait 2 seconds for synology manufactory device
>>: fa 03 01 00 00 00 fb
<<: fa 30 00 00 00 00 fb
>>: fa 02 00 80 00 00 fb
Mon May 15 01:57:07 UTC 2017
/dev/md0 /tmpRoot ext4 rw,relatime,journal_checksum,data=ordered 0 0
none /sys/kernel/debug debugfs rw,relatime 0 0
sys /sys sysfs rw,relatime 0 0
none /dev devtmpfs rw,relatime,size=253088k,nr_inodes=63272,mode=755 0 0
proc /proc proc rw,relatime 0 0
linuxrc.syno executed successfully.
Post init
[ 10.028543] EXT4-fs (md0): mounted filesystem with ordered data mode. Opts: barrier=1
[ 10.856704] EXT4-fs (md0): re-mounted. Opts: (null)
[ 13.335009] sd 0:0:0:0: Attached scsi generic sg0 type 0
[ 13.340456] sd 1:0:0:0: Attached scsi generic sg1 type 0
[ 13.598067] md1: unknown partition table
[ 14.022938] md: md_do_sync() got signal ... exiting
[ 14.028098] md: checkpointing resync of md1.
[ 14.032390] md: md1: current auto_remap = 0
[ 14.060092] md1: detected capacity change from 2147418112 to 0
[ 14.065973] md: md1: set sda2 to auto_remap [0]
[ 14.070521] md: md1: set sdb2 to auto_remap [0]
[ 14.075078] md: md1 stopped.
[ 14.077975] md: unbind<sda2>
[ 14.112943] md: export_rdev(sda2)
[ 14.116283] md: unbind<sdb2>
[ 14.152941] md: export_rdev(sdb2)
[ 14.771294] md: bind<sda2>
[ 14.774186] md: bind<sdb2>
[ 14.790051] md/raid1:md1: not clean -- starting background reconstruction
[ 14.796894] md/raid1:md1: active with 2 out of 2 mirrors
[ 14.802267] md1: detected capacity change from 0 to 2147418112
[ 14.808301] md: md1: current auto_remap = 0
[ 14.812509] md: resync of RAID array md1
[ 14.816468] md: minimum _guaranteed_ speed: 1000 KB/sec/disk.
[ 14.819558] md1: unknown partition table
[ 14.826368] md: using maximum available idle IO bandwidth (but not more than 200000 KB/sec) for resync.
[ 14.835817] md: using 128k window, over a total of 2097088k.
[ 15.191044] Adding 2097084k swap on /dev/md1. Priority:-1 extents:1 across:2097084k
==================== start udevd ====================
[ 16.360633] NET: Registered protocol family 10
[ 16.425913] sit: IPv6 over IPv4 tunneling driver
[ 16.739834] init: syno-auth-check main process (1657) killed by TERM signal
[ 17.713463] cryptodev: module license 'BSD' taints kernel.
[ 17.718976] Disabling lock debugging due to kernel taint
[ 17.899518] encryptfs using the OCF package.
[ 18.022000] fuse init (API version 7.22)
[ 18.105192] Loading modules backported from Linux version v3.18.1-0-g39ca484
[ 18.112316] Backport generated by backports.git v3.18.1-1-0-g5e9ec4c
[ 18.285649] zlib_deflate: exports duplicate symbol zlib_deflate (owned by kernel)
[ 18.380436] systemd-udevd[2043]: starting version 204
===== trigger device plug event =====
[ 18.498490] synobios: load, major number 201
[ 20.570950] pool #2: pkt_size=1536, buf_size=1600 - 2048 of 2048 buffers added
[ 20.578506] eth0: started
[ 20.581377] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 22.442165] init: dhcp-client (eth0) main process (3064) killed by TERM signal
[ 24.403706] ata1.00: configured for UDMA/133
[ 24.408035] ata1: EH complete
[ 24.412913] ata2.00: configured for UDMA/133
[ 24.417268] ata2: EH complete
[ 24.498581] synobios_ioctl: un-defined ioctl number c0044b25
[ 24.631688] init: synotifyd main process ended, respawning
[ 24.688423] ehci-pci: EHCI PCI platform driver
[ 24.785215] init: synotifyd main process ended, respawning
[ 24.844462] init: synotifyd main process ended, respawning
[ 24.905818] usbcore: registered new interface driver usb-storage
[ 24.955096] usbcore: registered new interface driver usblp
[ 25.048019] usbcore: registered new interface driver usbhid
[ 25.053679] usbhid: USB HID core driver
[ 25.174622] init: synotifyd main process ended, respawning
[ 25.220577] init: synotifyd main process ended, respawning
[ 25.318872] init: synotifyd respawning too fast, stopped
toasteroven login: [ 27.368439] ata1.00: configured for UDMA/133
[ 27.372741] ata1: EH complete
[ 27.450504] ata2.00: configured for UDMA/133
[ 27.454846] ata2: EH complete
[ 45.155124] md: md1: resync done.
[ 45.164403] md: md1: current auto_remap = 0
[ 75.713610] init: ssh-shell pre-start process (4744) terminated with status 127
[ 76.155059] init: ssh-shell post-stop process (4849) terminated with status 127
[ 77.475442] target_core_mod_4_0: version magic '3.10.77 SMP mod_unload ARMv7 p2v8 ' should be '3.10.35 SMP mod_unload ARMv7 p2v8 '
[ 77.553967] init: s2s_daemon main process (5165) terminated with status 127
[ 77.561083] init: s2s_daemon faild on spawn stage, stopped
[ 77.628838] init: sshd main process (4922) terminated with status 255
[ 77.663175] init: sshd faild on spawn stage, stopped
[ 79.194123] loop: module loaded
[ 83.120592] init: nmbd main process (5227) killed by TERM signal
[ 85.023614] synobios_ioctl: un-defined ioctl number c0044b24
[ 85.038213] synobios_ioctl: un-defined ioctl number c0044b26
[ 85.044432] synobios_ioctl: un-defined ioctl number c0044b25
