Remember to use UTF-8 codepackage! (Putty-Window-Translation-Remote character set-UTF-8)@Cricket-RJ
Not ao home right now. Anyway, it was only working holding some cables, so I guess the soldering was lame.
Thx again.
Not working… Did a FTDI self test looping RX and TX. It’s working. Removed the soldering and did it on the place said to use SATA cable (useless for me since the other end my jumpers got loose).
Same thing happened. Just weird characters, despite having the correct code page.
Since it got bricked after not waking up from stand by on very first use and got an eternal booting blue blinking led and two solid blue led even without a drive installed, I guess its really gone.
I’m definitively going to buy a Synology diskstation, that was the original plan.
Too bad…
@Cricket-RJ
Check the settings again:
If this is not working, try it first with minicom and then change the option maybe get the speed down?!
And you could post the output (strange charackters), maybe someone can help.
Double checked it on Putty and on Device Manager COM settings. Lower speeds still the same behaviour.
If I short tx-rx whatever I type appears on Putty, so thats why I don’t think it is the UART (FTDI FT232RL).
Still not looking good.
Uploading a 80k picture is taking forever. I guess I’ll torch everything on fire here!
@Cricket-RJ, Seems like data corruption, when connect Rx to Power (Or Rx to Rx).
Check connection.
Rx to Tx
Tx to Rx
GND to GND (“Ground”, “Minus”)
UART Pinouts (Tested by me. Photo from mine devices).
WDMC Mirror Gen1 (Ex2): https://ftp.anionix.ru/WDMyCloud/WDMyCloud-Mirror/Photos/Bottom.jpg
WDMC Mirror Gen2 (Ex2 Ultra): https://ftp.anionix.ru/WDMyCloud/WDMyCloud-Mirror-Gen2/Dev/Photo/UART_Pinouts.jpg
That’s how it’s done… Only weird chars yet.
It seems that is not responding to commands also, since pressing 1 to stop autoboot makes nothing happen.
Can it be the UART? Even passing on the tx/rx test?
Did the soldering again, with extreme care.
When I plug the UART and open Putty I’m able to write down things on the screen, so I guess the connection is fine.
When I power on, weird chars. Testes several speeds, always changing both on windows COM port and Putty. No response on pressing “1” key.
Is there a way to TFPT a clean boot image? Is there any other command to stop the booting sequence?
Thanks for all those replies. I guess my case in kinda unique here!
Oh, here’s an idea! What voltage of FTDI cable are you using? There are
some strange configurations out there that have things like 5v power and
3.3V Rx on the same cable. The important thing would be ensuring your cable
is 3.3V ex and not 5V. Because these devices are 3.3 and using 5 would
likely cause corruption.
Mine have a Jumper to change from 3.3 to 5V if desired. I’ve left it at 3.3V.
Right now I’ve left it on Putty for its eternal boot sequence, on a hope that will stop for itself sometime.
And how to reflash uBoot?
I can manage to connect on Win10 using Hyper Terminal. Would that help some way?
Another way to stop autoboot is short circuit TX with RX when “Hit any key……” come out , I tried ok. May it help! You can use Windows Hyper Terminal instead of Putty if it worked ok.
As for reflashing uBoot, I don’t have enough information or any hardware, just an idea heard from my crewmate. Sorry…
I don’t know when it shows, since only weird chars appears. I’ve kept pressing 1 like crazy for a few seconds. I’m gonna try for 3 minutes!
Funny thing is that the screen terminal keeps cleaning itself from time to time instead of scrolling down. Every time the screen cleans a windows beep is emitted.
Right now I just made to upload (or not) uImage to PCB. I’ve used Windows commando prompt with these lines:
mode COM4 BAUD=115200 PARITY=n DATA=8
copy uImage \.\COM4
After a few minutes of nothing, got “1 file(s) copied.” on screen.
Where do I find uBoot?
Dears,
Sorry about all the “flooding” here.
My guess is that NAND flash is busted (but some times almost comes alive) or I’m a terrible welder (despites this episode).
For 2 times I’ve got some mixed nice chars with weird ones, but stopped at the same spot with no responde.
Do you guys thinks the situation below is a data corrupcy because of a cold welding? At PuTTY with no power applied I can text freely with no weird chars. So I’ve “touched” the cables welded then weird chars appeared (MCM not powered). Then after no more weird chars powered of I’ve lit the unit and then the screen below appeared, but hanged.
Should I redo the welding? Actually asking a friend to do so…
I have some UART logs captured of a shutdown, reboot, and poweron. This is from an MCM Gen2 running Fox’s DSM firmware. It looks like the shutdown/reboot isn’t completing due to these SMI timeouts, which look related to the ethernet driver. Lets take a look:
admin@toasteroven:/$ [ 205.409900] mvEthPhyRegRead: SMI busy timeout [ 205.415194] mvEthPhyRegRead: SMI busy timeout [ 205.420468] mvEthPhyRegRead: SMI busy timeout [ 205.425749] mvEthPhyRegRead: SMI busy timeout [ 205.842192] mvEthPhyRegRead: SMI busy timeout [ 205.847469] mvEthPhyRegRead: SMI busy timeout [ 205.852757] mvEthPhyRegRead: SMI busy timeout [ 205.858031] mvEthPhyRegRead: SMI busy timeout [ 206.410940] mvEthPhyRegRead: SMI busy timeout [ 206.416238] mvEthPhyRegRead: SMI busy timeout [ 206.421512] mvEthPhyRegRead: SMI busy timeout [ 206.426792] mvEthPhyRegRead: SMI busy timeout [ 207.411894] mvEthPhyRegRead: SMI busy timeout [ 207.417187] mvEthPhyRegRead: SMI busy timeout [ 207.422467] mvEthPhyRegRead: SMI busy timeout [ 207.427740] mvEthPhyRegRead: SMI busy timeout [ 208.412923] mvEthPhyRegRead: SMI busy timeout [ 208.418200] mvEthPhyRegRead: SMI busy timeout [ 208.423488] mvEthPhyRegRead: SMI busy timeout [ 208.428763] mvEthPhyRegRead: SMI busy timeout [ 209.413564] mvEthPhyRegRead: SMI busy timeout [ 209.418841] mvEthPhyRegRead: SMI busy timeout [ 209.424134] mvEthPhyRegRead: SMI busy timeout [ 209.429407] mvEthPhyRegRead: SMI busy timeout [ 210.413797] mvEthPhyRegRead: SMI busy timeout [ 210.419074] mvEthPhyRegRead: SMI busy timeout [ 210.424365] mvEthPhyRegRead: SMI busy timeout [ 210.429639] mvEthPhyRegRead: SMI busy timeout sudo[ 211.414799] mvEthPhyRegRead: SMI busy timeout [ 211.420077] mvEthPhyRegRead: SMI busy timeout [ 211.425369] mvEthPhyRegRead: SMI busy timeout [ 211.430643] mvEthPhyRegRead: SMI busy timeout [ 211.873774] mvEthPhyRegRead: SMI busy timeout [ 211.879051] mvEthPhyRegRead: SMI busy timeout [ 211.884346] mvEthPhyRegRead: SMI busy timeout [ 211.889620] mvEthPhyRegRead: SMI busy timeout [ 212.415826] mvEthPhyRegRead: SMI busy timeout [ 212.421103] mvEthPhyRegRead: SMI busy timeout [ 212.426398] mvEthPhyRegRead: SMI busy timeout [ 212.431672] mvEthPhyRegRead: SMI busy timeout s[ 213.416825] mvEthPhyRegRead: SMI busy timeout [ 213.422122] mvEthPhyRegRead: SMI busy timeout [ 213.427397] mvEthPhyRegRead: SMI busy timeout [ 213.432680] mvEthPhyRegRead: SMI busy timeout hut[ 214.417826] mvEthPhyRegRead: SMI busy timeout [ 214.423123] mvEthPhyRegRead: SMI busy timeout [ 214.428398] mvEthPhyRegRead: SMI busy timeout [ 214.433678] mvEthPhyRegRead: SMI busy timeout down -[ 215.418052] mvEthPhyRegRead: SMI busy timeout [ 215.423346] mvEthPhyRegRead: SMI busy timeout [ 215.428620] mvEthPhyRegRead: SMI busy timeout [ 215.433902] mvEthPhyRegRead: SMI busy timeout h now[ 216.419058] mvEthPhyRegRead: SMI busy timeout [ 216.424352] mvEthPhyRegRead: SMI busy timeout [ 216.429625] mvEthPhyRegRead: SMI busy timeout [ 216.434906] mvEthPhyRegRead: SMI busy timeout [ 217.420032] mvEthPhyRegRead: SMI busy timeout [ 217.425326] mvEthPhyRegRead: SMI busy timeout [ 217.430600] mvEthPhyRegRead: SMI busy timeout [ 217.435878] mvEthPhyRegRead: SMI busy timeout
[ 217.903459] mvEthPhyRegRead: SMI busy timeout [ 217.908777] mvEthPhyRegRead: SMI busy timeout [ 217.914071] mvEthPhyRegRead: SMI busy timeout [ 217.919345] mvEthPhyRegRead: SMI busy timeout Password: [ 218.421088] mvEthPhyRegRead: SMI busy timeout [ 218.426386] mvEthPhyRegRead: SMI busy timeout [ 218.431660] mvEthPhyRegRead: SMI busy timeout [ 218.436941] mvEthPhyRegRead: SMI busy timeout [ 219.422078] mvEthPhyRegRead: SMI busy timeout [ 219.427354] mvEthPhyRegRead: SMI busy timeout [ 219.432641] mvEthPhyRegRead: SMI busy timeout [ 219.437914] mvEthPhyRegRead: SMI busy timeout
[ 220.422327] mvEthPhyRegRead: SMI busy timeout [ 220.427604] mvEthPhyRegRead: SMI busy timeout [ 220.432892] mvEthPhyRegRead: SMI busy timeout [ 220.438165] mvEthPhyRegRead: SMI busy timeout
Broadcast message from admin@toasteroven (/dev/console) at 16:03 ...
The system is going down for halt NOW! admin@toasteroven:/$ [ 220.669708] init: synonetd main process (1604) killed by TERM signal [ 220.681509] init: synostoraged main process (4151) terminated with status 15 [ 220.704596] init: hotplugd main process (4578) killed by TERM signal [ 220.738189] init: smbd main process (6056) killed by TERM signal [ 220.766097] init: nmbd main process (6538) killed by TERM signal [ 220.790026] init: synortc main process (6806) terminated with status 255 System is going to poweroff. [ 221.692336] init: Disconnected from D-Bus system bus [ 231.381319] md2: detected capacity change from 1995461165056 to 0 [ 231.387478] md: md2: set sda3 to auto_remap [0] [ 231.392040] md: md2 stopped. [ 231.394938] md: unbind<sda3> [ 231.452027] md: export_rdev(sda3) [ 231.458897] md3: detected capacity change from 1995461165056 to 0 [ 231.465045] md: md3: set sdb3 to auto_remap [0] [ 231.469593] md: md3 stopped. [ 231.472496] md: unbind<sdb3> [ 231.532025] md: export_rdev(sdb3) [ 233.048548] md: md0 in immediate safe mode [ 233.048570] md: md1 in immediate safe mode [ 233.057225] init: tty main process (4593) killed by KILL signal [ 233.063354] init: skip respawn tty during shutdown [ 233.082260] init: dhcp-client (eth0) main process (3651) killed by KILL signal [ 233.396524] EXT4-fs (md0): re-mounted. Opts: (null) [ 234.501446] sd 1:0:0:0: [sdb] Synchronizing SCSI cache [ 234.506723] sd 1:0:0:0: [sdb] Stopping disk [ 234.922125] sd 0:0:0:0: [sda] Synchronizing SCSI cache [ 234.927374] sd 0:0:0:0: [sda] Stopping disk [ 235.342429] xhci-hcd f10f8000.usb3: remove, state 1 [ 235.347336] usb usb4: USB disconnect, device number 1 [ 235.352643] xhci-hcd f10f8000.usb3: USB bus 4 deregistered [ 235.358161] xhci-hcd f10f8000.usb3: remove, state 1 [ 235.363070] usb usb3: USB disconnect, device number 1 [ 235.368357] xhci-hcd f10f8000.usb3: USB bus 3 deregistered [ 235.373890] xhci-hcd f10f0000.usb3: remove, state 1 [ 235.378791] usb usb2: USB disconnect, device number 1 [ 235.384047] xhci-hcd f10f0000.usb3: USB bus 2 deregistered [ 235.389557] xhci-hcd f10f0000.usb3: remove, state 1 [ 235.394468] usb usb1: USB disconnect, device number 1 [ 235.399732] xhci-hcd f10f0000.usb3: USB bus 1 deregistered [ 235.406029] Shutting Down Marvell Ethernet Driver [ 235.411652] mvEthPhyRegWrite: SMI busy timeout [ 235.417016] mvEthPhyRegWrite: SMI busy timeout [ 235.422380] mvEthPhyRegWrite: SMI busy timeout [ 235.426850] Power down.
Here are my thoughts and observations:
- Those SMI busy timeouts are always popping up. Others have reported seeing them flodding the dmesg output. They flood out the UART connection because that’s where all the dmesg entries go.
- The shutdown actually begins after it says “The system is going down for halt NOW!”. The SMI timeout messages end there, and processes are starting to get terminated. I see samba getting killed, and usb devices getting disconnected. And disks flushing and sopping. Last step is to shutdown the Marvel Ethernet Driver. Three SMI busy timeout messages appear. Then the final message is Power down.
- I would say the SMI busy timeouts are related to the Ethernet driver. Note that I don’t have the ethernet actually connected in this case.
- Not shown above, but booting takes ~35 seconds according to the timestamps. At that point I can log in with my admin account, but ~30 seconds later I first receive an SMI read-valid timeout. I’ll post a snippit below. After that it seems all the messages are about it being busy.
[ 32.579067] EXT4-fs (dm-3): mounted filesystem with writeback data mode. Opts: usrjquota=aquota.user,grpjquota=aquota.group,jqfmt=vfsv0,data=writeback,oldalloc [ 32.766539] EXT4-fs (dm-1): recovery complete [ 32.787407] EXT4-fs (dm-1): mounted filesystem with writeback data mode. Opts: usrjquota=aquota.user,grpjquota=aquota.group,jqfmt=vfsv0,data=writeback,oldalloc [ 33.628329] ata2.00: configured for UDMA/133 [ 33.632695] ata2: EH complete [ 33.636031] ata1.00: configured for UDMA/133 [ 33.640336] ata1: EH complete [ 33.694184] synobios_ioctl: un-defined ioctl number c0044b25 [ 34.167884] ehci-pci: EHCI PCI platform driver [ 34.382957] usbcore: registered new interface driver usb-storage [ 34.451668] usbcore: registered new interface driver usblp [ 34.653031] usbcore: registered new interface driver usbhid [ 34.658633] usbhid: USB HID core driver toasteroven login: [ 37.060644] ata1.00: configured for UDMA/133 [ 37.064979] ata1: EH complete [ 37.117163] ata2.00: configured for UDMA/133 [ 37.121483] ata2: EH complete [ 65.752749] md: md0: resync done. [ 65.768547] md: md0: current auto_remap = 0 [ 85.190921] mvEthPhyRegRead: SMI read-valid timeout [ 85.196770] mvEthPhyRegRead: SMI busy timeout [ 85.202061] mvEthPhyRegRead: SMI busy timeout [ 85.207334] mvEthPhyRegRead: SMI busy timeout [ 86.267187] mvEthPhyRegRead: SMI busy timeout [ 86.272499] mvEthPhyRegRead: SMI busy timeout [ 86.277777] mvEthPhyRegRead: SMI busy timeout [ 86.283078] mvEthPhyRegRead: SMI busy timeout [ 86.387545] mvEthPhyRegRead: SMI busy timeout [ 86.392871] mvEthPhyRegRead: SMI busy timeout [ 86.398159] mvEthPhyRegRead: SMI busy timeout [ 86.403487] mvEthPhyRegRead: SMI busy timeout
- I declare this powerdown not being successful, because the LED’s, fans, and ethernet is still powered, but maybe that’s not so accurate. The hard drives look powered down no? I just tried a reboot instead, and it also fails to really complete, so yea, i’d say this was not successful for very similar reasons.
admin@toasteroven:/$ Broadcast message from admin@toasteroven (/dev/console) at 16:03 ... The system is going down for reboot NOW! [ 201.363036] init: synonetd main process (1617) killed by TERM signal [ 201.369871] init: synostoraged main process (4183) terminated with status 15 [ 201.394674] init: hotplugd main process (4510) killed by TERM signal [ 201.439693] init: smbd main process (6265) killed by TERM signal [ 201.455840] init: nmbd main process (6567) killed by TERM signal [ 201.473629] init: synortc main process (6830) terminated with status 255 System is going to reboot. [ 202.429043] init: Disconnected from D-Bus system bus [ 212.117778] md2: detected capacity change from 1995461165056 to 0 [ 212.123936] md: md2: set sda3 to auto_remap [0] [ 212.128485] md: md2 stopped. [ 212.131381] md: unbind<sda3> [ 212.172002] md: export_rdev(sda3) [ 212.178868] md3: detected capacity change from 1995461165056 to 0 [ 212.185018] md: md3: set sdb3 to auto_remap [0] [ 212.189566] md: md3 stopped. [ 212.192470] md: unbind<sdb3> [ 212.232019] md: export_rdev(sdb3) [ 213.747950] md: md0 in immediate safe mode [ 213.752109] md: md1 in immediate safe mode [ 213.756751] init: tty main process (4523) killed by KILL signal [ 213.762937] init: skip respawn tty during shutdown [ 213.782286] init: dhcp-client (eth0) main process (3680) killed by KILL signal [ 214.052661] EXT4-fs (md0): re-mounted. Opts: (null) [ 215.134250] sd 1:0:0:0: [sdb] Synchronizing SCSI cache [ 215.139517] sd 0:0:0:0: [sda] Synchronizing SCSI cache [ 215.144842] xhci-hcd f10f8000.usb3: remove, state 1 [ 215.149749] usb usb4: USB disconnect, device number 1 [ 215.155071] xhci-hcd f10f8000.usb3: USB bus 4 deregistered [ 215.160582] xhci-hcd f10f8000.usb3: remove, state 1 [ 215.165495] usb usb3: USB disconnect, device number 1 [ 215.170774] xhci-hcd f10f8000.usb3: USB bus 3 deregistered [ 215.176316] xhci-hcd f10f0000.usb3: remove, state 1 [ 215.181218] usb usb2: USB disconnect, device number 1 [ 215.186469] xhci-hcd f10f0000.usb3: USB bus 2 deregistered [ 215.191979] xhci-hcd f10f0000.usb3: remove, state 1 [ 215.196890] usb usb1: USB disconnect, device number 1 [ 215.202166] xhci-hcd f10f0000.usb3: USB bus 1 deregistered [ 215.208375] Shutting Down Marvell Ethernet Driver [ 215.214008] mvEthPhyRegWrite: SMI busy timeout [ 215.219368] mvEthPhyRegWrite: SMI busy timeout [ 215.224732] mvEthPhyRegWrite: SMI busy timeout [ 215.229204] Restarting system. [ 216.228721] Reboot failed -- System halted
What do you guys think? Is this something you’ve encountered on your own platform Fox? Is there any more debug information that would be helpful?
@Fox_exe i try to use ftdi cable to recovery my mcm2, i cant boot from original kernel, but it stop at this screen
edit: i change to
fatload usb 0:1 0xa00000 /boot/uimage
fatload usb 0:1 0xf00000 /boot/uramdisk
bootm 0xa00000 0xf00000
its finnally working
after it reboot , it automatically boot into recovery mode, and upload the firmware in the webui, its backing to work as original
Someone can explain how wdfw-to-dsm.bin is created?
Thank you!
https://ftp.anionix.ru/WDMyCloud/WDMyCloud-Mirror-Gen2/DSM/Dev/dsm-wdmc-mirror-gen2.tar.xz
All sources and scripts inside.
(In short - need tool from WD gpl sources named “merge” and part of files from original firmware (Or create empty one))
Here you can find some info about this binary (Reverse engineering):
https://ftp.anionix.ru/WDMyCloud/WDMyCloud-Gen2/Developing/Заголовок%20прошивки.txt
