I have a small issue and maybe you can help me with that
I have 4 external Harddrives connected to the WDTV (working with a belkin-hub): 2 Movie HDs, 1 for TV-Series and 1 for Music.
Is it possible to give each HD a certain thumbnail which is displayed e.g. in the Video-Menu? I tried to put a “folder,jpg” in the root, but this won’t work.
i recently switched from kudos to this theme and added linksheets into it using the wdlxtv firmware mod. this theme is the best! definately a keeoer!! Now is there any way you have any genre folder covers premade or templates, fonts, etc?? thank you
ok i got it up and going nice now, thank you joey! i used movie sheet template from gbbm. Edited Genre folders that you referenced. Added xml edit to activate linksheets…here are screenshots of it all put together
I love this theme, but had to factory reset the box.
I re applied the theme, and no matter what it stays horizontal, I uploaded every version of the dark theme but even the one labeled VERT does not work.
What am I doing wrong?
i have absolutely no idea what you are talking about
oh :neutral_face: … if you’re talking about the Main Home Menu … yep, that’s Horizontal
i don’t have time or motivation for a GRID UI modification
Hi Joey, I’ve just downloaded and installed Alaska Dark and this is the first time I’ve installed a user theme so please bear with me if this is a dumb question. For some reason I cannot move on to the next page of the info in cases where the synopsis takes more than one page. Would appreciate any help. Thanks
P.S. Thanks for the lovely Theme and the easy instructions to add it to the SMP.
Ok, m first question is…
Is there a way or a hack to let us install a plexserver on the wd live hub.
Yes, directly on the hub, no NAS Drive, no extra computer, direct on the hub.
I have never used “Plex” in my life … i’m a XBMC / Kodi user
The WDTV Live Hub as never received any “Hacks” … (myself and some others assisted KAD79, but the Live Hub was too difficult to crack … so, No, you can’t install Plex)
The WDTV SMP had some hacks (dunno about Plex though …) http://forum.wdlxtv.com/
i’ve never used Simplicity Theme, that’s not my theme … plus I’ve haven’t used the abandoned “Thumbgen” software for a couple of years now, i’ll be surprised if it still works.
Looks so simple and easy… To bad it doesnt save the generated files, lol.
I wrote the support, lets see if they still active.
But you should look at it, just for information, its seems so easy.
Is there a theme for the hub you created and would recommended? If so, just tell me the name, i will find it
