I want to have admin access to the MBL from more than 1 machine. Can I just install the software on a different machine? Will I need a different admin password?
I want to remove Gigs of data off of a machine onto MBL. I want to do that via cable as that method is likely the fastest and most reliable. Can I connect the supplied cable to the ethernet port on a MacBook Pro and transfer files to the MBL that way?
You can do that froma any computer on the same network as the MBL, just type the IP address of the MBL on a browser (Or the name of your MBL ending in “.local” [DOTlocal]) and it will take you to the admin page. No additional software is needed for that.
Yes you can.
