My box was locking up increasingly frequently (when not in use, never when playing a film). Locked up maybe every few hours to maybe three or four days at random (required a re-boot every time).
I’ve replaced my nearly full (USB attached) 2TB WD Passport with a 3TB WD Passport - problem solved, it’s now rock solid.
I’m pretty sure the 2TB drive is OK. I’ve previously tried re-formatting it and copying all my files back onto it. It didn’t make any difference to the reliability.
I can’t believe having a nearly full drive causes problems.
A hard drive is not like a drawer you can cram full. Best practices with a HD is fill it no more than 90% or so. It needs some free space for HD kinds of operations.
I keep a backup copy of all my films. I tried formatting the 2TB drive and re-copying all the files back. This did not fix things, I guess that’s as good as running CHKDSK.
Since I never get a failure whilst watching a film, the problem was an irritation rather than a show stopper (Ha!). If the problem returns with the 3TB drive I think I’ll just leave the box powered off until I need to use it. A bit of a bind since the WDTV takes about 4mins in total to boot up and sort itself out.
Fingers crossed it stays reliable. Since it’s working fine with the 3TB drive i’m reluctant to spend any more time trying to find out why it was failing with the 2TB drive.
