We have a Pioneer network receiver system (X-HM82) on which we played music from our old WD Cloud. We have had to upgrade to a new WD My Cloud Home but we cannot make the music system find the new cloud. Previously we pressed Music server on the remote and the old cloud was listed on the display. We could then scroll down to it and select. The new cloud is not listed on the display. How can we find it and connect?
- MCH web app, ‘Do More’, enable Plex
- Authenticate Plex with a free account
- Enable DLNA within Plex, no need to install any other Plex apps
Thanks. We’ve been trying to enable Plex but it can’t connect to My Cloud Home . The error message is
app.plex.tv is unable to connect to “My Cloud Home” securely
Its “Secure connections” setting may be set to disabled, or you may need to adjust some settings on your network. You can learn more about secure connections here.
The link says to edit secure connection settings via Settings>Server>Network
but we don’t appear to have those menu options.
Have you already looked at this?
Learn How to Cofigure and Use Plex For My Cloud Home (wd.com)
Nobody really like to support Plex on the MCH. Western Digital treats it as 3rd party software which they don’t support beyond making it available. Plex treats Plex on the MCH as abandoned-ware and support on the Plex community forum is lacking from which you will be lucky to get a reply on any subject on MCH.
Try this first:
