Got a new receiver, Onkyo TX-NR646 which lists AAC support as a feature. The WDTV, latest model, does not detect it during the audio HDMI auto config process, and forcing AAC support using the manual option results in no sound.
Have others been successful in having the WDTV detect AAC support in a receiver?
***** EDIT ****
In looking through the full manual, the 646 does not support AAC over HDMI, only for file playback.
It seems like you’ve already identified the issue with your Onkyo TX-NR646 receiver not supporting AAC over HDMI, as indicated in the manual. This limitation can indeed affect the auto configuration process and result in no sound when you force AAC support using the manual option.
