I thought AAC was a supported format for MKV files but apparently it is not or I have made some error while enocding the files. Here is the info for one of the problematic files
C:\Documents and Settings\PcOne\Desktop\01.mkv
General
Unique ID : 204708154166548079381023635157331701821 (0x9A015B3CD4C4DD60A23BFCFA4C2B703D)
Complete name : C:\Documents and Settings\PcOne\Desktop\01.mkv
Format : Matroska
File size : 91.8 MiB
Duration : 23mn 56s
Overall bit rate : 536 Kbps
Encoded date : UTC 2008-07-17 11:19:39
Writing application : mkvmerge v2.0.2 (‘You’re My Flame’) built on Feb 21 2007 23:40:55
Writing library : libebml v0.7.7 + libmatroska v0.8.1
Video #1
Format : AVC
Format profile : High@L5.1
Format settings, CABAC : Yes
Format settings, ReFrames : 8 frames
Codec ID : V_MPEG4/ISO/AVC
Duration : 23mn 56s
Nominal bit rate : 500 Kbps
Width : 640 pixels
Height : 480 pixels
Display aspect ratio : 4:3
Frame rate : 29.970 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.054
Writing library : x264 core 56 svn-676
Encoding settings : cabac=1 / ref=5 / deblock=1:1:1 / analyse=0x3:0x133 / me=umh / subme=6 / brdo=1 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / chroma_qp_offset=0 / threads=3 / nr=0 / decimate=1 / mbaff=0 / bframes=5 / b_pyramid=1 / b_adapt=1 / b_bias=0 / direct=1 / wpredb=1 / bime=1 / keyint=250 / keyint_min=25 / scenecut=40(pre) / rc=2pass / bitrate=500 / ratetol=1.0 / rceq=‘blurCplx^(1-qComp)’ / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / pb_ratio=1.30
Audio #2
Format : AAC
Format/Info : Advanced Audio Codec
Format profile : HE-AACv2 / HE-AAC / LC
Codec ID : A_AAC
Duration : 23mn 56s
Channel(s) : 2 channels / 1 channel / 1 channel
Channel positions : Front: L R / Front: C / Front: C
Sampling rate : 48.0 KHz / 48.0 KHz / 24.0 KHz
Compression mode : Lossy
Any way of getting these files to work without rencoding them ?
TIA,
Nosx
