Guys, I’m following the directions in the other thread, downloaded the last firmware version 2.01.86 and copied to a thumb drive.
Boot the media player and I get the message new firmware available so I go into that and its showing me current version 2.02.32
New version 4.01.86
I don’t want to downgrade till I know if this is a TYPE-O or is this what should be showing
Downloaded from here:
http://support.wdc.com/KnowledgeBase/answer.aspx?ID=5860
Thanks in advance
Think I found it guys; makes sense now LOL
Hamlet
3
Thank you for sharing the solution to your issue.
