500 MB WD5000AZRX Model not found
Anyone knows where I can found Advanced Format Software (last version 2.0.111) for this hdd? It’s so new that it can’t be found in WDDC web. I have registered it but I can’t download the sofware because it’s so new that isn’t in wdc database registration cataloge.
Thanks,
Weird, is not even listed in WD website.  You should contact WD support to verify this.
Thanks,
Even when the drive model is not listed you can download the software
The app is not drive specific therefore you can use it with any advance format drive
Get it from here
