5.1 Channel Sound from WD
If i copy the Contents of Movie DVD (.vob and audio files ) to a USB Drive and connect that USB to watch movies using the WD TV Mini, will i get the 5.1 chanel output from the WD Media player, below are the connection.
Components Connections
WD TV mini → Yamaha rx-v467 AVR via Optical Audio Cable
WD TV mini → Samsung Led using YPBR cable.
Hi there, checking the user manual for the Mini, I found this:
  • Stereo or multi-channel digital surround (pass through only) audio output
So yeah, it should do it.
