I’m sorry guys, i’ve read and tried everything except reformatting my drive because it takes me lots of time to move my files in.
Truth be told, i just bought my 3TB MyBookLive and upgraded to the latest FW. and yes like everyone else i’m also experincing the Remote Access issue. What’s more is I’m only have a 4MB/s transfer rate???
I’ve ruled out the WebDAV by following the steps, i’ve also unmapped the drive and re-mapped by IP, checked-i’m on Gbit port of my modem, my MyBookLive is connected directly to my modem. Alls done but i’m still having a 4MB/s transfer rate.
I’m running windows 7, no firewall except connection OUT to internet.
IP: IP of your drive or MyBookLive should also work
Username: root
Password: welc0me
First backup smb-global.conf located at /etc/samba/smb-global.conf by copying it to your computer
In WinSCP right click on smb-global.conf and select edit
REMOVE “max protocol = SMB2” from the bottom of the file and close and save the file
Reboot the MBL
This will drop the drive back to SMB
If after rebooting your drive you see the same speeds, open up WinSCP again and copy your backup smb-global.conf file over the modified one at /etc/samba and again reboot and you will be back to SMB2
I agree with this, did the update since last friday. Before the update, LAN speeds can go more than 4MB/s. After the latest update, the speed only goes to about 3-4MB/s.
What is worst, now with direct connect LAN to PC, I could not access the public shared folders except when using WinSCP (again, slow 4MB/s speed). Before the update, I used to access the shard folders through “Run”, “\(ipaddress)\public”, now I get errors:-
“IP_Address” is not setup to establish a connection on port “file and printer sharing (SMB)” with this computer
However, when I type my MBL IP on the browser, I can access the login into the dashboard. I just cannot access shared folders without WinSCP. When I connect MBL through WiFi, I can see the shared folders like normal.
Well hopefully WD sort this all out and do it fairly quickly… I thought I was in bad shape when my speeds dropped from around 46MB/s write to 35/MB/s write and 70MB/s read to 50MB/s read. I couldn’t imagine 4MB/s…
It’s TP-Link model TL-WN727N, a wireless N USB Adaptor.
Tested with SpeedTest.net, seems like i’m able to achieve at least a 30Mbps down and a 30Mbps up. As such, the wireless adaptor shouldn’t be the cause of the slow transfer.
