I had a drive which i RMA’d. The drive lost all its performance after a month of use. I am just today reading that WD green drives will take a 3.3x performance hit when they become “misaligned” by using certain varieties of linux and windows . I use windows XP and have the drive as a tertiary device.
The formatting utility below should re-align the drive without damaging the data. However, as always, you should still back up all your data in case you lose the partition.
Oh i just realized that this drive is EADS not EARS. i guess it was just a bad drive then, the last one i rmaed… since as i understand it, this problem\feature does not exsist on the EADS drive.
