I recently bought 2x My Book Elite (2 TB), and they are working just great.
But, I can’t seem to have both connected on the same time.
When i connect them both, only one can be accessed.
I have the most recent firmware on both of them (v2.010).
When both is connected, one can be accessed but the second one is not possible to access. When i go into Disk Management (Win 7 x64) the disk don’t seem to get a partition drive letter. And when i right click on the drive every choice is grayed out. when i go into WD SmartWare the disk that i’m not able to access is marked with “No writable WD SmartWare partition found”.
It’s always the first disk to be connected that is accessible. the second drive is none accessible.
When i connect them one by one, they get the same partition drive letter.
The problem seem to be that both drives gets the same partition drive letter. i have tried to change them back and fourth but no luck so far.
Anyone got any idea how to deal with this problem ?
Hi SpeedySpyro. I have the same problem. I have the same OS, the same hard disk. If you have any solution, please contact me at yaren@quartieridifabula.eu or in this discussion and vice versa. Thanks in advance
