Hi all,
I was running 2.02.32 without too many problems UNTIL I put the wdtv live on a “private network” connected to a router by ethernet so that it would get a DHCP address but with the router not connected to the internet.
It will run fine for about a day, then everything will get super slow and won’t respond to the remote properly without massive delays. When I try to play something from a local network file it will give me a low memory warning and then ask me to reboot.
It was working perfectly until I disconnected it from the internet. Now it will last about 24 hours before the dreaded low memory warning. One of the reasons I liked the WDTV Live boxes was that they would play local content. They shouldn’t freak out if I don’t want to connect to the net.
Going to rollback to the previous firmware and see if that helps.
