Does anyone know if the 16TB WD Red Pro (WD161KFGX) works with the PR2100? I’ve seen from the compatibility page that the 18TB version is, but wondering if there would be any issues in using the 16TB version instead?
Does your PR2100 use OS3 or OS5? Creating this topic in the correct sub-forum for your device may get faster help.
Hope you noticed this sub-forum is for the My Cloud Home.
User Manual: My Cloud Home and My Cloud Home Duo (westerndigital.com)
