I “accidentally” upgraded to OS 5 4 days back. Problem:-
whenever I plug in my Segate 10Tb USB hub (powered) the NAS hangs, I can no longer access the dashboard (unexpected error) and file explorer says “windows is unable to access 192.168.150”. i then need to pull the power cord and re-start to get it going again
However a Seagate 5Tb USB drive in the same slot works just fine. Anyone else facing a similar issue?
- Do you have “Mobile and Web Cloud Access” set to ON at the share level for both 5 and 10 TB USB hubs?
- What is the difference between the 10 TB and 5 TB? IE: partitions, filesystem format, etc…
- Have you opened a support case? If Yes, what’s your case number?
I do not have “Mobile and Web Cloud Access” set to on for any of my shares. In the case of the 10 TB hub – it no longer shows up in my shares
The 5 TB is a Seagate USB disk with a single partition ExFAT. The 10 TB is a powered Segate USB drive with 2 additional USB inputs
No I have not yet opened a support ticket
Additional info – Since this problem began, around 5 days ago, on two occasions the 10 TB actually managed to connect without a fuss (screenshot attached)
