Hello, I’m facing the following problem :
I have a 5000AAKS and a 1001FALS on my system running Windows XP on an ASUS P5K-E motherboard
Some time ago I noticed that the 1TB Caviar Black (1001FALS) started performing poorly. I ran HD Tune Pro and found that, in the benchmark section, 1001FALS could reach at most 4.2 MB/s when reading. The other one (the 500GB Caviar Black) ran fine, reaching reading speeds of 70-80MB/s. I moved the FALS on another SATA slot, and it started working fine (the benchmark showed speeds of over 100MB/s). But, after awhile (a few days or so) the problem reappeared (after booting the PC, the FALS started performing poorly). Moving the FALS on another SATA slot will sometimes make it work (for awhile, as I said before). When working ‘properly’ and continously reading from the HDD (watching a movie), it sometimes gets ‘stuck’, it is as if it attempts to read some data, but fails and it retries for about 20-30 seconds, staying in this loop - the HDD indicator is showing activity during this time.
I tried a lot of different cables, enough to be sure that the cable wasn’t the issue
In conclusion :
1001 FALS performs really bad - reading speeds up to 4.2 MB/s
moving it on another SATA slot will fix this temporarily
when working at normal speeds, the HDD sometimes gets stuck trying to access data
SATA cable not an issue
In the Health tab of HDD Tune Pro, the Reallocated Sector Count shows 100 and Current Pending Sector shows 270. Any ideas regarding this ?
