1 My Book Deosnt work As Adpter for data trasfer
My 600 My Book recently fell , it has fell before, but somehow I broke the as adettor. I have one other My book a TB and two other  external hard drives. is there some way i can hook it up by using the the usb ports with outs the ac adaptor by the usb ports only. I have to do data transfer or if  i can use this only by the usb ports :-? i would surly hate to loose my only 600gb one
Thank you :smiley:
Running on  7>64bit>4GB of ram  > Hopes that helps :–?
How do you mean you broke the adapter?  Did you break the power adapter plug on the drive itself?
