Hallo!!
Habe ein Problem mit Meiner WDTV Live (1.05.04_V-WDLXTV-Live-0.5.1.1).
und zwar ist das DATUM immer auf 01.01.2000 gestellt.
Verwende meine WDTV Live mit einen WLAN-STICK.
WAS MACHE ICH FALSCH?
Hier die S00custom-options
#!/bin/sh
## in this file you can enter commands that will be executed with the init.d scripts
## typos / syntax errors will prevent the osd from booting
## this file is only executed if it is at the root of an attached device at boot
## NO REFLASH IS REQUIRED: S00custom-options is executed EVERY boot
## several examples are provided below, uncomment (delete #) them to use
## config_tool commands only need to be executed once then they can be re-commented
## NOTE commenting a config_tool command does NOT disable it
## you must change a setting back to default manually
## NOTE: THIS FILE IS FAIRLY DEPRECATED AND NO LONGER CONTAINS EVERY OPTION
## YOU ARE RECOMMENDED TO NAVIGATE TO THE WEBEND AND USE THE WLDXTV CONFIGURATOR
## SIMPLY ENTER YOUR WDTV’S IP ADDRESS IN YOUR BROWSER AND L/P IS:
## wdlxtv / wdlxtv
## change background image between 3 stock options, or arbitrary location
## background image **CAN NOT** be larger than 512KB
## the following three images are included in the firmware
## original background:
## eM82's backdrop background:
## Pennhaven's chrome backdrop background:
## wood panel (default) background:
## To set an absolute location:
#config_tool -c BACKGROUND_IMAGE=/tmp/mnt/123ed956-1256-4825-9e79-86fc1e0febaa/random/location.jpg
## You can also supply an image, on an attached device at boot (like S00custom-options),
## which is 1280x720 and *NO* larger than 512KB named villa_bg.jpg and it will be used as the custom background
## *ONLY* villa_bg.jpg will work in this method, and *you may remove the device if you desire* after the background has been loaded
## change screen saver image between wdlxtv & original WD logo's, or arbitrary location
## wdlxtv logo
## original WD logo
## some random location (absolute)
#config_tool -c SCREEN_SAVER_IMAGE=/tmp/mnt/123ed956-1256-4825-9e79-86fc1e0febaa/some/random/screensaver-image.png
## which is *NO* larger than 512KB named screen_saver.png and it will be used as the custom screen saver image
## *ONLY* screen_saver.png will work in this method, and *you may remove the device if you desire* after screen_saver.png has been loaded
## Enable linksheets moviesheet scanner for moviesheets
## REQUIRED on non-1.02.21 based WDLXTV's!!!
#config_tool -c LINKSHEETS=ON
## Movie sheet modes (only one can be enabled at a time)
## unless you have sheets for each mode you will encounter oddities switching around modes
## AKA this isn't magic
## Full screen std mode:
#config_tool -c MSHEETMODE=std
## 1280x460 (horizontal banner at top) sheet mode:
#config_tool -c MSHEETMODE=sheet
## 500x720 (vertical banner on right) wall mode:
#config_tool -c MSHEETMODE=wall
## turn on moviesheets for a list type (ON/OFF)
## you must turn it on for a view type to see sheets!
## video thumb mode
#config_tool -c VIDMSHEET=ON
## audio/photo thumb mode
#config_tool -c GENMSHEET=ON
## list mode (video/audio/photo)
#config_tool -c LISTMSHEET=ON
## enable a central moviesheet repository
## allows all moviesheets to exist in one location
#config_tool -c MSHEETDIR=/tmp/media/usb/someWhere
## enable auto framerate/resolution functionality
#### keeps OSD at menu selected resolution,
#### but changes to suit every viewed video
#### also downmixes multi-channel AAC -> stereo, so that it plays on the wdtv
## to customize settings edit /conf/autores.conf
#config_tool -c AUTORES=ON
## enable forced-HDMI resolutions instead of highest compatible EDID
#### this setting is for displays who have bad EDID
#### or whose display has hidden resolutions not in the EDID
## ****this setting should not be dangerous, but still be careful****
#config_tool -c FORCEHDMI=ON
## enable auto-zoom overscan fix
#### this setting zooms out automatically the
#### number of times below, when videos are played
#config_tool -c DEFAULT_ZOOM=1
## change list view to 4/6/8/11 entries
#config_tool -c LISTNUM=4
#config_tool -c LISTNUM=6
#config_tool -c LISTNUM=8
#config_tool -c LISTNUM=10 (default)
#config_tool -c LISTNUM=11
#config_tool -c LISTNUM=12
## change video thumb view to various amounts of thumbs
#THUMBRESO=120x160 has been removed due to OSD crashing issues
#config_tool -c THUMBRESO=150x200 # 12
#config_tool -c THUMBRESO=163x245 # 8 (default)
#config_tool -c THUMBRESO=180x240 # 10
#config_tool -c THUMBRESO=225x300 # 4
#config_tool -c THUMBRESO=240x360 # 4
## change music/photo thumb view to 10/15 thumbs
#config_tool -c GENTHUMBS=10 # 10
#config_tool -c GENTHUMBS=15 # 15 (default)
## change video info overlay
## ( for subtitle viewing during pause/timing/etc)
## requires reboot after change
## upper ~60%
#config_tool -c VIDEO_INFO_BAR=2
## top (warning: options bar covers up info overlay with setting 3)
#config_tool -c VIDEO_INFO_BAR=3
## change subtitle size to one not menu-selectable
#config_tool -c SUBTITLE_FONT_SIZE=44
#config_tool -c SUBTITLE_FONT_SIZE=48
#config_tool -c SUBTITLE_FONT_SIZE=50
#config_tool -c SUBTITLE_FONT_SIZE=52
#config_tool -c SUBTITLE_FONT_SIZE=56
#config_tool -c SUBTITLE_FONT_SIZE=60
#config_tool -c SUBTITLE_FONT_SIZE=64
#config_tool -c SUBTITLE_FONT_SIZE=68
#config_tool -c SUBTITLE_FONT_SIZE=72
#config_tool -c SUBTITLE_FONT_SIZE=76
#config_tool -c SUBTITLE_FONT_SIZE=80
## permanently set timezone
## http://www.timeanddate.com/library/abbreviations/timezones/
## below is for Pacific North America
config_tool -c TIMEZONE=PST8PDT
## permanently set hostname
#config_tool -c DEVICE_NAME=SomeHostName
## use custom USB slot icons (default: ON)
#config_tool -c USBICONS='OFF'
## disable telnet server (default: ON)
#config_tool -c TELNETD=OFF
## set custon telnet server port (default: 23)
#config_tool -c TELNETPORT=49532
## disable pure-ftpd server (default: ON)
#config_tool -c FTPD=OFF
## disable dropbear ssh server (default: ON)
#config_tool -c SSHD=OFF
## set custon dropbear ssh server port (default: 22)
#config_tool -c SSHPORT=62356
## disable keep alive of ethernet during WDTV Live standby
#config_tool -c DISABLE_ETHERNET_ON_STANDBY=YES
## delay net.mounts execution in case of wireless adapter usage and shares not showing up
#config_tool -c NET_MOUNTS_DELAY=30
## automagic IP obtain at boot (default: OFF)
## required for NTP=ON
config_tool -c IPUP=ON
## enable NTP - network time (default: OFF)
## ***NTP requires IPUP=ON***
#### ***ONLY with wireless: NTP adds ~20s to the initial boot of the device***
#### ***due to the bringing up and acquisition of wireless network address***
## -- if NTP fails because of slow address acquire you can increase delay to NTP_DELAY
config_tool -c NTP=ON
## custom NTP server
config_tool -c NTPSERVER=pool.ntp.org
## NTP delay is seconds (in case of slow wireless adapter)
config_tool -c NTP_DELAY=42
## Disable mt-daapd digital audio server (saves ~10MB ram)
#config_tool -c MT-DAAPD=OFF
## Disable pandora binary (saves ~2MB ram)
#config_tool -c PANDORA=OFF
## Disable UMSP (default: ON - REQUIRES APACHE=ON TO WORK)
#config_tool -c UMSP=OFF
## Disable Apache webserver (default: ON)
## WARNING: Disabling Apache will make UMSP, youtubeHD, shoutcast, and (of course) the webend stop working!
#config_tool -c APACHE=OFF
## enable rtorrent bittorrent client (default: OFF)
## ***SSH server must be enabled to start rtorrent***
## ***apache webserver must be enabled to use webui***
## RTORRENT_DIR *MUST* be set for full functionality!
## rutorrent & rtorrent DEPEND on it
#config_tool -c RTORRENT=ON
## set rtorrent data location for incomplete/session/finished/rutorrent
#### the line below is an EXAMPLE! To have your device mounted at /tmp/mnt
#### create a file on it called: .mnt
#config_tool -c RTORRENT_DIR=/tmp/mnt/123ed956-1256-4825-9e79-86fc1e0febaa/
## Enable nzbget usenet client (default: OFF)
#config_tool -c NZBGET=ON
## Disable online-delayer (in case of stalled network detection)
## or because nzbget / rtorrent / net.mounts / etc won't execute
#config_tool -c ONLINEDELAYER=OFF
## power actions are executed when the OSD is suspended/resumed
## ***NOT*** executed when your wdtv live comes on from cold boot / power cycle
## executed when:
## -----the wdtv live goes into standby via remote
## -----the wdtv live wakes up from suspend via remote
## --use S00custom-options or S00user-script for actions that happen at boot
## ***DO NOT EXECUTE usb.power.on OR usb.power.off IN ETHERNET ACTIONS*** SEE USB_POWER_OFF setting ***
## [you may have number actions which are executed in order]
#config_tool -c POWER_UP_ACTION='logger -t "power_up_action" "I am doing something"'
#config_tool -c POWER_UP_ACTION20='sleep 5; ether-wake -b xx:xx:xx:xx:xx:xx; sleep 10; /etc/init.d/S90net.mounts start'
#config_tool -c POWER_DOWN_ACTION='logger -t "power_down_action" "the OSD has been suspended!"'
## Enable/Disable Samba Windows share server (default: OFF)
## ON:
#config_tool -c ENABLE_SAMBA_SHARE=1
## OFF:
#config_tool -c ENABLE_SAMBA_SHARE=0
## Change SMB resolve order to 'proper' order
## YMMV
## this MUST contain either valid settings or be blank
## stock/official firmware order:
#config_tool -c SMB_RESOLVEORDER='bcast lmhosts wins host'
## proper/corrected order:
#config_tool -c SMB_RESOLVEORDER='lmhosts host wins bcast'
## fixes missing / non-working network shares (bad DNS):
#config_tool -c SMB_RESOLVEORDER='lmhosts wins bcast'
## Change Samba share export to not allow guest (anonymous) mounting
## smbpasswd is stored in /conf
#### This setting requires a reboot if executed manually (telnet/ssh instead of S00 script)
#config_tool -c SAMBA_SERVER_PROTECTION_STATE=1
#config_tool -c SYSTEM_USERNAME='SambaUser'
#config_tool -c SYSTEM_PASSWORD='SambaUser'
#config_tool -c SMBSHARE_USERNAME='SambaUser'
#config_tool -c SMBSHARE_PASSWORD='SambaUser'
## Enable guest read only access, plus user protected write access
#### This setting makes no sense without the settings above set
#config_tool -c SAMBA_PROTECTION_WITH_GUEST=1
## Disable/enable Samba exported shares on standby (default: ON)
#config_tool -c SMB_STANDBY=OFF
## Disable/enable Samba auto export mode (default: ON)
#config_tool -c SMBD_AUTO=OFF
## set Samba Workgroup
#config_tool -c SAMBA_WORKGROUP=SomeWorkgroup
## Enable NFSD kernel NFS server (default: OFF)
#config_tool -c NFSD=ON
## Enable NFSD auto export mode (default: OFF)
## (requires NFSD_AUTO_DEFAULT)
## (overrides /conf/exports)
#config_tool -c NFSD_AUTO=ON
## NFSD auto export mode default setting
#config_tool -c NFSD_AUTO_DEFAULT='192.168.0.234(rw,async,no_subtree_check) 192.168.0.199(rw,async,no_subtree_check)'
## turns off 5V to USB Bus on standby (when you press power off on remote)
## this action is prevented by the following:
## - root.bin active
## - OSD Theme active
## - Optware active
## - app.bin active
## - Deluge or NZBget enabled
#config_tool -c USB_POWER_OFF=1
## Select one of the extra translations, that is not selectable from the language options
## Only possible to set ONE locale
## Choices:
## - Netherlands: nl
## - Greece: gr
## - Catalan: ca
## - Hungarian: hu
## - Slovak: sk
## - Polish: pl
#config_tool -c LOCALE=nl
#config_tool -c LOCALE=gr
#config_tool -c LOCALE=ca
#config_tool -c LOCALE=hu
#config_tool -c LOCALE=sk
#config_tool -c LOCALE=pl
## enable YouTube Switcher (You can only use one at a time!)
## to enable YouTube HD:
## ***youtubeHD requires setting YOUTUBE_QUALITY too***
#config_tool -c YOUTUBE_SWITCHER=youtubeHD
## to enable EasyNews XViD proxy:
#config_tool -c YOUTUBE_SWITCHER=easynews
## to disable YouTube Switcher:
#config_tool -c YOUTUBE_SWITCHER=''
## EasyNews YouTube Switcher settings
#config_tool -c EASYNEWS_USER=user
#config_tool -c EASYNEWS_PASSWORD=password
## youtubeHD YouTube Switcher quality setting
#config_tool -c YOUTUBE_QUALITY=270P
#config_tool -c YOUTUBE_QUALITY=360P
#config_tool -c YOUTUBE_QUALITY=480P
#config_tool -c YOUTUBE_QUALITY=720P
#config_tool -c YOUTUBE_QUALITY=1080P
## Live365 Switcher (You can only use one at a time!)
## to enable Shoutcast
#config_tool -c LIVE365_SWITCHER=shoutcast
## go back to live365
#config_tool -c LIVE365_SWITCHER=''
## EIRI (remote control remapping & action)
## requires /conf/eiri.conf or eiri.conf on device at boot
#config_tool -c EIRI=ON
## WDTVExt internal plugin debug level
## 0 : logging disabled (default)
## 1-5 : higher levels of output (1 least -> 5 most)
#config_tool -c MOVIESHEET_DEBUG=5
#config_tool -c RELOADER_DEBUG=5
## WDLXTV Census - registers your device with fwup.wdlxtv.com
## ****100% optional****
## ***default: OFF***
#config_tool -c WDLXTV_CENSUS=ON
## extra NLS / codepage packages (for non-english character filesystems)
## NLS packages (default utf8)
#config_tool -c IOCHARSET=utf8
#config_tool -c IOCHARSET=ascii
#config_tool -c IOCHARSET=euc-jp
#config_tool -c IOCHARSET=iso8859-13
#config_tool -c IOCHARSET=iso8859-14
#config_tool -c IOCHARSET=iso8859-15
#config_tool -c IOCHARSET=iso8859-2
#config_tool -c IOCHARSET=iso8859-3
#config_tool -c IOCHARSET=iso8859-4
#config_tool -c IOCHARSET=iso8859-5
#config_tool -c IOCHARSET=iso8859-6
#config_tool -c IOCHARSET=iso8859-7
#config_tool -c IOCHARSET=iso8859-9
#config_tool -c IOCHARSET=koi8-r
#config_tool -c IOCHARSET=koi8-ru
#config_tool -c IOCHARSET=koi8-u
## codepage packages (default cp437)
#config_tool -c CODEPAGE=cp1250
#config_tool -c CODEPAGE=cp1251
#config_tool -c CODEPAGE=cp1255
#config_tool -c CODEPAGE=cp437
#config_tool -c CODEPAGE=cp737
#config_tool -c CODEPAGE=cp775
#config_tool -c CODEPAGE=cp850
#config_tool -c CODEPAGE=cp852
#config_tool -c CODEPAGE=cp855
#config_tool -c CODEPAGE=cp857
#config_tool -c CODEPAGE=cp860
#config_tool -c CODEPAGE=cp861
#config_tool -c CODEPAGE=cp862
#config_tool -c CODEPAGE=cp863
#config_tool -c CODEPAGE=cp864
#config_tool -c CODEPAGE=cp865
#config_tool -c CODEPAGE=cp866
#config_tool -c CODEPAGE=cp869
#config_tool -c CODEPAGE=cp874
#config_tool -c CODEPAGE=cp932
#config_tool -c CODEPAGE=cp936
#config_tool -c CODEPAGE=cp949
#config_tool -c CODEPAGE=cp950
DANKE!!
