PM4 WD - (A Non-Moviesheet “Grid UI” Modification Theme port of the Project Mayhem skin for XBMC)
This Theme is for the *NEW* WDTV Media Player and the WDTV Live SMP (Latest Firmware 2.02.32)
(WDTV Live Hub owners … the Home Menu Will Not Work on Your Device … the other views will) *
Please carefully read the Release Notes below *Download Link* below
NEW User Requested Gallery View Mod
* It’s Experimental … not all views / features completed (ie.Watched Icons etc.) , may contain bugs
* Written to work with the WDTV Live SMP and the WDTV Media Player using the Grid Interface (Latest Firmwares)
* Home Screen uses “Linksheets” 1040x520 use *jpg or *png and remove the file extension and place into theme folder and re-zip
* Will keep tinkering around with it … time permitting
PM4 WD … DOWNLOAD LINK: http://www.mediafire.com/download/vyq22j9dqjumuhe/PM4_WD_v1.3.zip
PM4 WD GALLERY MOD … DOWNLOAD LINK: http://www.mediafire.com/download/uw9na1306knpodw/PM4_WD_v1.3_GMOD.zip
PM4_WD_v1.3
Changelog
Added : AOL.On and WD MyCloud text icons introduced in Firmware 1.02.17
Added : User Request Modified Gallery View. This version named PM4_WD_1.3_GMOD (link above)
PM4_WD_v1.2
Changelog
Fixed : “Play” button does not work when pressed on a file or folder
PM4_WD_v1.1
Changelog
Fixed : folder icons displaying on the home screen (gone now)
Fixed : info_sub too long (shortened the width and added scrolling)
Fixed : file list view (select bar wrong width)
Fixed : list view name length (to compensate for Media Server Source duration eg. 00.04.000.Minutes)
Added : dynamic weather backdrops (configure and add “Accuweather” service to home screen
Added : modification of online services screen to home screen
Added : modification of options screen for adding and deleting home screen shortcuts
Added : more online services labels english only (includes UK & US … Thanks KAD79 for the image references)
Added : active services and setup icon (bottom right of home screen… scroll up to top of list then left/right)
To Do : Lots … Video and Music playback screens next plus other views time permitting
How to install a Theme {Guide}
To install the theme, download the zip file to your PC, open your web browser (I don’t recommend using IE8 or IE9, there have been issues), then type your WDTV’s IP address to open the Web UI.
(Find your WDTV’s IP from Setup > About)
Type in your password (the default is “admin”), click on the box next to “I accept” and then click on LOGIN, then click on “Appearance”, then click on “Browse” and navigate to where you saved the “PM4_WD.zip” file, then click on “Open”.
Click on “Submit”, then once the Web UI finishes uploading the theme (which will take approx 30 secs), on you WDTV press “Setup” on your remote, select “Appearance”, then select “User Interface Themes”, select “PM4_WD” then when prompted select “Apply theme”.
