Which XML are you using to base this on ? Gallery I guess, since this is the only XML that handles meta-data? Or are you creating different thumbs with description for each file?
I might try something similar on my Ohagi-theme, inspired by this - if that’s fine by you? I really like the clean-nes’ of that wall-mode. If I were you, I’d go all the way and loose the weather and time icons as well
I like having the clock, reminds me to stop watching and go to bed
If I could get the film wallpaper to resize and fit about the movie name, I would loose the clock to make space.
I’ve done a similar (almost identical) setup now. Looks good, but very buggy unfortunately. I’ve set mine up, so that you can scroll up/down to go up-down the wall. Going down is pretty smooth, but going up is slow and gets really buggy. How have you set yours up regarding navigation?
Mines works nice and smooth, I’ve included the file above you post.
Thanks - I’ve tried your XML out now. Again - nice work - looks great!
I do, however, have the same issue with your version. Have you actually tried it out in a folder where you have more than 24 files i.e. more than one page…?
I’ve not got many that have more that 24, the most I have is 30, so the 2nd page doesn’t have a lot on it.
I will add some more files and try it out this week.
for me, it seems that it is the actual “page-change” that causes bugs, so a folder of 30 files should reveal the issue if you jump back and forth on the pages…
I have notice that if your on the 1st row, you can move the cursor off the top of the screen. I guess its trying to hover over the 4 coloured buttons, that aren’t there anymore.
what part of the xml provides the text for the description of the move that to the left, i cannot find it anywhere, thank u, will this work for the rv_video_browse_page as far as the text wise or is that gallery only
To fix this in “rv_gallery_browse_page.xml” delete the line " ", this will keep it from trying to find the Dashboard, Filter/Sort, etc. buttons.
Look for the variable @@browse_text , that one and the 3 that look after the metadata.
Thanks, will give a go tonight.> I’ve got a couple more tweaks I want to try anyway. Like adding a white line around each thumbnail to make then stand out a little> * * *
sk1dmark, I don’t want to be a mood killer here - especilly b/c I think this wall-mode looks great. But there are some major-bugs in this - not caused by your XML, but simply because it seems the HUB cannot handle this setup. I’ve been messing around with it for some time now, trying to fix it - no luck. I’m not saying it cannot be done - just that the Lord and apparently the WD HUB works in mysterious ways sometimes :)
Before getting to fixated around all the little graphical details, I would advice you to try and get the basic working 100%. I’m saying this because it might not even be possible and you’d have to discard the whole thing, having spent hours and hours on it. (believe me, done this several times now
I would be happy to help if possible and test stuff out - I would really like to see this setup working!!
