Hi all,
Like many others here, I had major performance issues after upgrading to 2.02.32 (extremely slow and unresponsive interface).
Tonight I decided to rollback to the previous firmware using the instructions here:
http://community.wd.com/t5/WD-TV-Live-Streaming/2-02-32-Firmware-no-longer-allows-content/m-p/781937#M32423
The rollback seemed to be successful, but after booting up, I could not set up WiFi (“Wireless”) any more. When I go to setup-> network settings-> network setup, I only see “automatic” and “manual” options available, instead of “wired” and “wireless”.
I’ve tried factory resetting via the menu, as well as the physical reset button. I also re flashed the rollback firmware multiple times, and I even manually flashed the 2.02.32 firmware one more time to see if I could regain WiFi. I’m having no luck, and no way to connect to my PC any more, on any firmware! Any help would be appreciated.
On the bottom of the device, it is labeled “WD TV Live Streaming Media Player”.
P/N: WDBHG70000NBK-02
The unit was purchased brand new from Costco more than a year ago and I’ve never had any WiFi issues until now.
