Using WD TV live hub media without TV
Hello
I would like to use me WD without TV.
For example I would like to select music and play playlist on my stereo without switching ON the TV.
Is it possible to do it ?
I know we can do it for example with Windows media player using the function “sending to” but it is very limited
(once you have sent the playlist with windows media player through the function “sending to” to WD, you don’t have anymore control on the music excepting stopping the playlist and re-do the operation from beginning)
thanks for your help
Rodolphe
Nope… Xbmc with an android app does the job, but then you have to
Buy something else
