Reply
Occasional Contributor
0
Problem with metasource and metadata
I have a few questions about the metadata for films and tv shows in the Live Streaming:
-It's possible to add new metasources? How?
-It´s possible to add metadata to a folder? I think it is interesting for tv shows
-I don't find metadata for tv shows. How can do it?
Thanks very much and sorry for my poor english
Miguel
Respected Contributor
0
Re: Problem with metasource and metadata
Yes, look at the user manual, page 190.
http://www.wdc.com/wdproducts/library/UM/ENG/4779-705062.pdf
No.
The name of the show is fundamental, for example:
terranova.S01E03 show give you results.
0
Thanks, but in the page 190 say
"Select Add New Meta-Source and select the meta-source XML file from the
network or attached USB storage. You can also create your own meta-source. Go
to www.wdtvlive.com to download a sample meta-source, and for more information
about meta-sources."
However, the url www.wdtvlive.com IS WRONG,
then I can´t download a sample metasource.
Please help me.
Occasional Visitor
0
I am unable to find any meta-source downloads or samples or any information at all on how to make one anywhere on the www.wdtvlive.com site.
Regular Advisor
I'd also like an answer on this as well.
As I want to change the meta-source for TV shows.
Maybe I'll email WD and see what they have to say.
If you like my feedback, hit the kudos button.
Also, please show your support for true .png's below -
http://community.wdc.com/t5/WD-TV-Live-Hub-Issue-Reporting/PNG-s-do-not-display-correctly-for-files-folder-thumbnails/idi-p/268062
