I have recently had a problem with Netflix in that whenever I run it, it seems to not be able to load and says it fails with an error. After doing some digging, it looks like it’s got an SSL handshake error. I’ve also noticed that the time is wrong on the box (by about 9 hours!) so I wonder if the time could be the cause of the SSL error. I can’t seem to set the time, only the timezone which is correct, so I think it must be a bug of the box. Has anyone else had this problem?
