I have some problems to read some AVI files on my WD TV Live.
The audio part is good but the video is freezing.
I can view this file perfectly on PC.
Please help! I have this issues with a few AVI files.
Is it possible to convert the files?
I don’t know which parameter I should change.
example:
Video
Format : MPEG-4 Visual
Format profile : Advanced Simple@L5
Format settings, BVOP : 2
Format settings, QPel : Yes
Format settings, GMC : 3 warppoints
Format settings, Matrix : Default (H.263)
Muxing mode : Packed bitstream
Codec ID : XVID
Codec ID/Hint : XviD
Duration : 23mn 3s
Bit rate : 1 242 Kbps
Width : 720 pixels
Height : 576 pixels
Display aspect ratio : 16:9
Frame rate : 25.000 fps
Standard : PAL
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.120
Stream size : 205 MiB (90%)
Writing library : XviD 1.2.1 (UTC 2008-12-04)
WDTV does not support “Global Motion Compensation” aka. GMC
http://www.wdc.com/en/products/products.aspx?id=330&wdc_lang=en
You will have to Re-Encode the entire Avi without GMC to be playable on the WDTV
Your video has GMC…
Video
Codec ID : XVID
Duration : 23mn 3s
Width : 720 pixels
Height : 576 pixels
Thanks for your quick reply.
Do you know which program I should use to re-encode my files?
I just checked some other files.
Here there is no warppoints in gmc…
What’s the problem here?
Format settings, BVOP : 3
Format settings, QPel : No
Format settings, GMC : No warppoints
Codec ID : XVID
Duration : 12mn 19s
Bit rate : 1 211 Kbps
Width : 720 pixels
Height : 540 pixels
Display aspect ratio : 4:3
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.125
Stream size : 107 MiB (90%)
Writing library : Lavc54.77.100
dunno about that one Aydwyn ? … dodgy corrupt perhaps ?
for re-encoding … i use Handbrake. if you’re in a hurry choose MPEG-4 (FFmpeg) mp4 if not … then H.264(x264) mkv
(sometimes i use Avidemux or Virtualdub or XVID4PSP depending on wether i wanna get fancy with filters and upsampling audio channels etc)
anyways, there’s heaps of software you can use to re-encode a video with (Google is your friend)
P.S. I just noticed your video clips have a pretty short duration … re-encoding them will not take long
depending on your PC maybe 10-15 mins ? each (if that)
Aydwyn
6
I don’t know for that one too.
For the first one, I reencoded with AVS video converter and it works fine!
Thanks again!
IIRC few standalone players support Qpel, GMC, packed bitstream (the latest of which can be removed with MPEG4 Modifier without recoding).
