I followed the suggested Dlink DWA-125 nad inserted it to the usb port on WDTV. Nothing happened and I cant setup the wireless network. Any help
Amin
Amin
The SMP doesn’t require a wireless dongle, wifi is built in to the unit itself. Do you require the dongle for your pc to connect wirelessly to the SMP?
Cheers
Do you have the OLD Live or the New Live Streaming which has built in Wifi?
My WDTV is not with WiFi
… then you’re in the wrong forum.
The correct forum is here:
http://community.wdc.com/t5/WD-TV-Live-Networking/bd-p/wdtv_live_networking
… only the revisions mentioned in this document:
are supported, which for the DWA-125, means revision A1 or A2 only.
