Hi, I was just wondering if the following will work in my WD TV Live Media Player: Cisco-Linksys WUSB600N Dual-Band Wireless-N USB Network Adapter. Since I will like to stream the Videos wirelessly from my computer at a 5GHZ rate. I already own a Cysco E300 Router…
I have been using the WUSB600N V2 adapter since August, and it has been working great for me. I am using it with a Netgear WNDR3700 V1. With this combination I can dedicate the 5GHz radio to video streaming and the 3700 uses internal algorithms to give priority to the video streaming. It sounds like you want to do the same thing.
If you look at the list of approved adapters, you will see that both versions of the WUSSB600N are listed.
